Replacing Head Gasket: parts list
Old Dec 4, 2004 | 02:36 PM
  #91
carF150's Avatar
Yeah, all of them on that side do not make continous contact.
Old Dec 4, 2004 | 04:44 PM
  #92
JMC's Avatar
JMC
25 Year Member
This would indicate that they were starved for oil. That means that an oil passage is blocked or is leaking. As you say you did not dismantle the head that leaves a clogged gallery as the only plausible explanation. You said that the head had oil in it when you removed the cover. Did both sides look like that had the same amount of oil.
JMC
Old Dec 4, 2004 | 05:10 PM
  #93
Ted'98's Avatar
carF150 - I just had a thought. Is it possible that you put the head gaskets on the wrong sides or possibly got two of the same head gasket?
I triple checked which gasket I was putting on each side since they are side specific.
If the wrong gasket is installed, that could be blocking all the oil passages into the head????
Old Dec 5, 2004 | 02:14 PM
  #94
FloppyJoe's Avatar
Originally posted by JMC
Here is a picture of a disassembled lash adjuster. It fills up with oil under pressure and pushes up against the follower to take up the slack.
Here is a picture of the follower and the lash adjuster. The camshaft lobe pushes against the roller in the middle, the lash adjuster removes the slack and the other end pushes against the valve to open it. Disregard the one on the left it is a different version. The one on the right is what you have in your truck.
jmc, i'm curious. how do these work when you first start your engine and there's no oil pressure?
Old Dec 5, 2004 | 04:18 PM
  #95
JMC's Avatar
JMC
25 Year Member
A lash adjuster will stay pumped up beacuse of the spring and the oil inside it. Oil is fed through a passage in the cylinder head. As long as oil is sent to the lifter it will stay inflated. When the supply of oil is stopped the action of pushing against the follower will push the oil out of it and it will deflate.
JMC
Old Dec 5, 2004 | 07:09 PM
  #96
carF150's Avatar
I got my head back off and here is what I found. The gasket has an R on it and it doesn't seem too fit any other way.
Old Dec 5, 2004 | 07:30 PM
  #97
JMC's Avatar
JMC
25 Year Member
When you replaced the gasket the first time did you reuse the old head bolts?
JMC
Old Dec 5, 2004 | 07:43 PM
  #98
carF150's Avatar
No, I used new head bolts.
Old Dec 5, 2004 | 08:50 PM
  #99
FloppyJoe's Avatar
Was that coolant in there the first time you took it off?
Do the pistons have any damage like they hit the valves?
Old Dec 5, 2004 | 08:59 PM
  #100
carF150's Avatar
The pistons look ok. I cant just pull any of them out, so I know they are broke. Should I start taking apart the lash adjusters? What should I check on the head ?
Old Dec 6, 2004 | 12:51 AM
  #101
JMC's Avatar
JMC
25 Year Member
You need to remove the lash adjusters to see what is wrong with them. Oil is fed to both the lash adjusters and to the cam bearings through a passage. At both ends of the head it is capped off by a plug with an allen key. The oil is supplied to the passenger side head from a feed hole at the firewall end of the head on the passenger side head. The cam cap with the 3 bolts is the end that has the oil feed coming up from the block. If that feed hole is blocked or restricted it will starve the bearings and also the lifters for oil and they will collapse.
JMC
Old Dec 6, 2004 | 01:02 AM
  #102
JMC's Avatar
JMC
25 Year Member
What is all that stuff floating in the liquid in the cylinders? What is the liquid, antifreeze?
There is a mark on the # 2 piston in the middle that looks like a crescent. What is that? On the head the #3 combustion chamber has something covering the exhaust valve near the bottom. Is that a shadow or something that is actually there? I recommend you take the head to a shop and have them look at it.
JMC
Old Dec 8, 2004 | 08:09 PM
  #103
Ted'98's Avatar
carF150 - how is it going?
Old Dec 8, 2004 | 08:45 PM
  #104
carF150's Avatar
Well, I am in my first year of pharmacy school and finals are coming up and am getting my butt kicked. I haven't done much since I got the head back off. I emailed my dad and brothers some of those pictures and they said they didn't think those valves on the head should be open. They thought the valves should all be closed, so maybe I have some bent valves through there. I am going to wait until the 17th when finals are over and start taking apart the valves and lash adjusters and checking them all out. Thanks for all of your help along the way.
Old Dec 8, 2004 | 09:03 PM
  #105
y2kxlt's Avatar
It looks like the valves hit the pistons more than likely because it was out of time. In cylinder #2 I can see an indention on the piston that looks like the shape of the valve. This will bend the valves and cause no comperssion on the cylinders affected which would explain why it wouldn't stay running.
