Replacing Head Gasket: parts list
#62
I approached this a little differently than other procedures I've seen. Instead of putting the chains on with the engine at TDC, I rotated the engine to a safe mode and then timed everything.
First I put my engine in TDC, then once I had the front cover off, I moved the keyway in the crank to 12:00 so the engine was in safe mode.
I then bolted both heads down. I layed out my two chains and marked the ends. I then put the crank sproket on. I put the drivers chain on first - I put the mark on one end of the chain on the mark on the crank sprocket. I then rotated the driver head so the other mark on the chain lined up with the mark on the cam gear.
I did the same thing for the passenger side. You want to rotate the engine at least 2 times to make sure you don't have any PTV contact.
I was ultra paranoid and rotated the engine 50-60 times to get all the marks on the chains to line up the the cam/crank gears.
Hope that helps.
Hope that helps.
#63
#67
#68
#71
on
Check the IAC to be sure it is not stuck shut or that it doesn't have an obstruction somewhere in the tubing or valve itself. The TPS could be misadjusted and showing an off idle condition where the butterfly is still closed. Or there could be a vacuum leak between the MAF and the intake manifold where it attaches to the heads.
JMC
JMC
#74
I was talking to some guys about it this past weekend and they thought that maybe when my brother and I did the timing, we didn't have tdc. We had the crank in tdc for the exhaust stroke and not the compression stroke. So we did the timing when in exhaust and not compression tdc. Does that sound logical to you guys? When I redo the timing I think I will get a compression gauge and put it into #1 and check for compression. Does that sound like a good idea?
#75
on
car,
Do you have a shop manual? The most important step is to rotate the crankshaft so the keyway points to the 12 o'clock position. This position allows the rotation of the cams without damaging the valves and or pistons. The tritons are an interference engine. Meaning that the valves will strike the piston if they are opened when their piston is at TDC. Once the crankshaft is positioned the cams can be rotated. Remove the chains. The LH cam is rotated till its timing mark is approximatly at the 12 o'clock position. The RH cam goes to the 11 o'clock position. Tighten the cam holding tools.
turn the crankshaft counter clockwise till the keyway is at the 10:30 o'clock position. This is TDC on #1 cylinder. This should position the crank timing marks at 6 o'clock. Install the chains.
JMC
JMC
