Replacing Head Gasket: parts list
#106
#107
#108
on
If the valves were pushed back into the head even if oil was getting to the head the lash adjusters would have been pushed till they colapse and jam, then the valves get bent. If that is the case the headwill have to be examened to make sure it did not crack and that the valve guides are still intact.
JMC
EDIT: The book says to discard the gasket.
JMC
#109
#112
#113
#115
Yeah, i got it all figured out and it is running like a champ now. It seems as though when I put the timing chain back on I had the timing off on the right side and bent all four intake valves. When I was pulling the valves one of the valve guides came off also, so I had a machine shop do a valve job for me. Thanks so much for all of the help you gave me along the way.
