Replacing Head Gasket: parts list
#49
Everything is put back together and here is what I got.
http://www.s89667659.onlinehome.us/p...les/almost.wav
#55
you should turn the crankshaft pulley until it's at that TDC (top dead center) mark. This means that cylinder number one is at the top of the compression stroke so both of it's valves should be closed. With the valve covers off you should be able to tell if that cam is pushing the valves open on that cylinder or not. You might want to make a mark on the chain and the sprocket so you know where you started cuz you shouldn't be off by much. and if that turns out not to be what was wrong you'd know where to put it back at.
#56
#57
#58
