Best intake?
Best intake?
Is there a difinitive answer as to which intake is best? I'm looking at 4 different ones, the K$N, Airraid, Air Force 1, and Volant. I think the K$N is probably off the list because I didn't like the fit and finish on my dad's 99. I'm open to suggestions on the others, mainly the AF1 and volant.
Thanks,
Mitch
Thanks,
Mitch
Guest
Posts: n/a
I didn' t think that K&N made a full intake for our 4.2's. If they do, I would have gotten that. Only because they have been in business for as long as I can remember.
I do however, currently have the Volant. It's great. Only problem, the pretty blue filter turned pretty GRAY!
It still sounds good, and that makes me think that it is good performance wise.
You really have to ask yourself what you want in an intake.
Looks?
Performance?
Cheap?
or top of the Line?
from what I hear MAC is solid and its a good price. People will state, why pay $230 for an intake when you can pay $140 for the MAC and get a nice metal tube that does just as good a job as the $230 piece?
think about it.....
Looks?
Performance?
Cheap?
or top of the Line?
think about it.....
I'm looking for preformance, I don't care about looks, and the cost difference isn't that much in the long run if the product is better. My buddy put an airraid intake on his otherwise stock truck, it made a big difference. I still need to be able to smoke him by several truck lengths...
Mitch
Mitch
Guest
Posts: n/a
Sorry guy to burst your bubble, but an Intake alone is not gonna be the mod to help you beat your buddy to finish line.
List what mods you currently have and what your friend has. Truck type is helpful too.
Regardless, there is no Intake that is gonna give you significant gains. In fact, be prepared to only feel 5Hp's at the most. If you combine it with an exhaust, then that combo right there will be good. Then of course you should chip your truck.
Guest
Posts: n/a
Even if you got the most expensive Intake at $250....I would save the hundres bucks, spend $140 for the MAC and use that saved $100 towards an exhaust if you don't have yet, or a chip!
You can easily spend under a hundred bucks to cut out the factory muffler and replace it with a Flowmaster (Delta 40 I heard was good and inexpensive).....
Guest
Posts: n/a
LBC150:
now that looks HOT! I like that kit. I should've gone with the metal tube. I don't know, someone just convinced me to go with a plastic tube kit to keep the air slightly cooler (d*mn salesmen )
when changing the airfilters, are they all compatible from manufacturer to manufacturer? or do I have to take the time to actually measure my filter's opening?
I've got Volant.....by the way.
I'm not looking to gain 3-4 lengths on him, I can still beat him by at least 2 lengths, so I'm looking to get back that 1 he gained when he added the intake. I used to beat him all day by 3 lengths. I think there is a substancial reduction in flow from the flex section of the factory intake, so I want a better intake.
Our trucks are very similar, both 4.2 5 speeds with 3.55 gears and 275/60/17 tires, I went with a magnaflow, he did flowmaster. I have the modified airbox with K&N, he got the airraid kit. I have a chip, he doesn't. He has a LS differential, so he usually gets a little better launch than I do, but I pull right past him in the top of second gear.
Here's the sig again:
Mitch
Never put my truck on a dyno, but I would be surprised if the Airaid or comparable FIPK only added 2-5 hp.
FWIW, on my truck, the Airaid made absolutely no noticeable difference in power below 3,000 rpm. However, above 3k there is a noticeable improvement. Not as much improvement as adding the chip, but a gain nonetheless. I had heard the intake systems added approx. 10 hp to our trucks, which seems about right to my 'butt dyno'.
Guest
Posts: n/a
my bad Bronco man...with such simple questions, I figured you were all stock.
how is it that you have a chip and your friend only has LS rear and an Airraid and he can still keep up with you?
I'd figure that the chip alone would leave him behind.
Wow, just the intake alone improved your buddy's truck by 1 truck length!
Watch out, he may get chipped and then what?
***it makes me feel gloomy reading you guy's signatures with all your mods....one day when I grow up, I'll be a BIG BAD V6 just like my bros......
I'm not 100% convinced that the chip is all it's cracked up to be. I'm planning on adding a set of JBA headers and an intake, then having it reprogrammed.
Sorry for my basic questions. I was basically asking for a consensus on the best intake from the group based on performance. It sounds like they are all about the same, so I'll probably save some $$$ and get the MAC one. Does anybody have an installed pic of the MAC one?
Thanks,
Mitch
