Tachometer installation on 00' 4.2 xl
Been trying for to get my sunpro supertach II to work all day long with no luck. Read several older post for help but still no luck. any help would be much appreciated.
00' 4.2l Stepside
5 sp manual
K&N FPIK
Flowmaster 40 series
Superchip
00' 4.2l Stepside
5 sp manual
K&N FPIK
Superchip
Yea ive been trying to do that forever and i finally found out why it doesnt work. For some reason on the 99 and up models they did something with the tach signal wire so that you cant just hook up a tach to it. Its not impossible, people have done it with ignition systems but i find it hard to believe that the only way we can get a tach in the truck is to spend $400 on an ignition box. Also in the new Truckin' magazine somebody wrote in asking them how to install a tach on the 99 and up ones but they weren't helpful. They just said to recheck your connections and try a little harder.
http://albums.photopoint.com/j/View?...nce=4&res=high
'99 F150 4.2L XL SC Shortbed, KN Filter Flowmaster exhaust Lightning exhaust tips
Superchip
285-60-18 Falken Ziex ST tires
18" Lightning Rims
Superwhite headlights Kenwood Mask cd player
Cerwin Vega 3way speakers
1 MTX 12" Subwoofer
2" rear drop shackles
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
Superchip
18" Lightning Rims
1 MTX 12" Subwoofer
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
I finally got it hooked up today. I found an older post explaining the proccess. The message was posted by "LTDC" and it is located in "APPEARANCE PRODUCTS". He posted a message that explains it, I did it and it worked fine.
00' 4.2l Stepside
5 sp manual
K&N FPIK
Superchip
00' 4.2l Stepside
5 sp manual
K&N FPIK
Superchip
Really? I guess I will have to go and check it out.
Superchip
18" Lightning Rims
1 MTX 12" Subwoofer
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
Superchip
18" Lightning Rims
1 MTX 12" Subwoofer
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
I read his post. I will have to try it on my truck tommorow and pray that it works or else im stuck again. Thanks for letting me know where it was.
Superchip
18" Lightning Rims
1 MTX 12" Subwoofer
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
Superchip
18" Lightning Rims
1 MTX 12" Subwoofer
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
Nope it didnt work at all i still got no signal. How did you hook up your tach wire. If i followed the instructions right you go thru the computer connector but i couldnt find any wire connectors that would work so i just tried to stuff it in there.
Superchip
18" Lightning Rims
1 MTX 12" Subwoofer
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
Superchip
18" Lightning Rims
1 MTX 12" Subwoofer
Bilstein Shocks
Headlight Strobes
Euro Clear Corners
I also just stuffed mine in there, but made sure it was pushed down in the notch so that it wouldn't touch anything else. seems like there was another msg left by someone saying they couldn't get it to work either. Might try it again to make sure it got a good connection, it could've slipped out just enough to lose connection.
00'xl 4.2l Stepside
5 sp manual
K&N FPIK
Superchip
Betterbuilt Quantum
Toolbox
00'xl 4.2l Stepside
5 sp manual
K&N FPIK
Superchip
Betterbuilt Quantum
Toolbox
