Get to know everyone
Old Mar 31, 2008 | 01:44 AM
  #76
tj03f150's Avatar
you've still not answered my questions as to the tuning part.
as well as eveerything else. at 34psi u should have much more power than that.
Old Mar 31, 2008 | 01:46 AM
  #77
tj03f150's Avatar
Originally Posted by 4.2L_Guy
bud bud bud bud bud u got it all wrong all wrong... i meant the 10 psi when i said it to be your psi!!! bud the powerstroke makes 28 lbs of boost completly stock!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !! 34 with the chip... diesel make way more boost then gas!!!!!!!! ever will!!! go to a convience store and get the diesel power mag... there are pickups in there that make 110 lbs of boost!!!!! 34 is nothing really... diesel make way more boost then gas will ever think of makeing!!!!!! sry u got that all mixed up!!!!!!!!!!!!!!!!!!!!
ive yet to read everything you said here but a chip does not make more psi. unless your boost is controlled electronically then i guess so.
maybe were just comparing apples to oranges here and that why nothing makes sense.
to turn up the boost on my truck i have to adjust the wastegate or boost controller.
Old Mar 31, 2008 | 01:47 AM
  #78
dirtyd88's Avatar
yall can keep this fight going until morning, and i will make sure to ask who wins. i have class in the morning, so im hitting the sack. i will make sure to let yall know when i get the dyno results, and how much i added to the numbers...
Old Mar 31, 2008 | 01:48 AM
  #79
04heritage's Avatar
actyually the numbers are calculated numbers so a sheet wont tell you... 398 rwhp and 761 rwtq... sry for the confusion. but with the formula they used to tell me what i got at the fly i cant remember the formula but that was the numbers at the fly... i
HAHAHA!!!!!!! 398 hp with 34 psi? And is the 398 flywheel or rear wheels? you got me confused.
  #80
4.2L_Guy's Avatar
Originally Posted by tj03f150
okay wait ..
you've got 34psi... and still have a limiter? set to 100?
im only at 8psi and my limiter has been bumped to 127.
something smells a bit fishy.
i dont see how they can even tune without moving that limiter up. and 34psi ... i would assume built block.
is this ur moms daily driver or does she race this thing
D D she dnt drive it we just call it hers... casue i have a pickup dad has one... and thats just the other one...lol we just call it hers so we no which one were tlkin bout... 34psi is nothing for a stock block on a diesel.... here go to this website dieselpowermag.com and read some forums learn a little bout diesels and what kind of boost they make... then u will see im not lieing at all lol the site is awesome
moms pickup also gets 19mpg on ave.
Old Mar 31, 2008 | 01:50 AM
  #81
4.2L_Guy's Avatar
well yeah its controlled electroninly... everything on a diesel is now days... go to dieselpowermag.com and read for urself about diesel's if u dnt belive me.
Old Mar 31, 2008 | 01:51 AM
  #82
tj03f150's Avatar
these people here
http://www.thedieselstop.com/forums/...stions-192451/
say that a stock diesel turbo setup is 6-7psi...
they must be full of ****.
Im not doubting that a diesel can do 34psi... but your tellin me that it comes with 20 something psi stock. and that u guys only bumped it up a little bit
Old Mar 31, 2008 | 01:52 AM
  #83
4.2L_Guy's Avatar
wrong like i said 28 lbs stock!!!! and stock hp at the rear wheels is only about 295hp diesel's are difrent then gas go to dieselpowermag.com!!! trust me u will learn alot about diesel just by reading the forums...
  #84
tj03f150's Avatar
dieselpowermag.com sure yah but i expect those to be built.
Old Mar 31, 2008 | 01:56 AM
  #85
4.2L_Guy's Avatar
y do u think diesels have so much more trq then gas... they have so much more boost!!!!! and thats y diesels are way better for towing... hp= acceleration trq= pulling power (in a diesel) semi's have 600hp and upwawrds of 2100 lbs of trq!!! thats y they can move so much heavier stuff!!! the brand new powerstroke's make 39 lbs of boost stock!!!!!!! cause there dual trubo!!!! i know that casue they come stock with a boost gauge and i know moms boost becasue we put aftermarket guages on there so we can monitor the boost the egt the water temp and one more but i cant think of it off the top of my head... o yeah the trans temp.
Old Mar 31, 2008 | 01:58 AM
  #86
4.2L_Guy's Avatar
were they tlkin bout semi's or pickups pickups make more then semi's casue there pumpin more air threw a smaller turbo... semi's only make about 15... but the turbo is so huge that they dnt get much psi but they get way more flow!!!! a semi turbo is twice as big as a pickup turbo...
Old Mar 31, 2008 | 01:59 AM
  #87
dirtyd88's Avatar
thats why it takes them 5 minutes to moveacross an intersection...they will never be enough air to make massive amounts of boost in a turbo the size of a basketball...
Old Mar 31, 2008 | 02:01 AM
  #88
4.2L_Guy's Avatar
diesel's also make more trq casue there pistons are so much bigger then a gassers... take yours out and they will be what at the most 2 inches in diameter... just a guesss.... take a semi's out they are more they are more then 6 inches in diameter... thus making that much more explosion everytime!!! now a pickups pistons would be smaller like 3 to 3.5 inches in diameter
  #89
tj03f150's Avatar
okay,
i believe you..
but i dont beleive its as fast as you think it is.
not trying to be a ****.. just something wasnt making sense to me.
heres all the timeslips and dyno sheets etc of these f250's 350's etc
http://www.dragtimes.com/Ford--F350-Drag-Racing.html
but you still gotta give me half a track length
Old Mar 31, 2008 | 02:02 AM
  #90
4.2L_Guy's Avatar
it takes them that long to move cross the intersection casue they have 18 gears to pick form ware u only have 4 in an auto... and it takes a while for that big of a turbo to spool!!!
