Anybody over 100,000 miles with factory engine
Old Aug 4, 2008 | 04:52 PM
  #121
Canada_Firetech's Avatar
Hey I have a 1999 4.2 V6 Supercab whit 211000 KMS i don't know how many miles it is but should be close to a 100 000 miles. Never touch the motor .
Old Aug 4, 2008 | 08:02 PM
  #122
rpm1's Avatar
Sorry wrong engine...what an amature I am - 1999 F150 XLT 2WD 5.4L with 198,000 origional owner miles
Currently (thanks to you all) looking at doing my front ball joints. I've got excessive wear on the front right inner tire.
I try to do everything myself. This forum has made this possible for me and I thank you.
Gone bad:
Interminent driver side window issue that went away around 2003 (usually occured after a rain)
HVAC temp control **** started going 2002 Although I can still get it to work it takes a little finessing.
Battery Cable down by the starter in...2002
New Tie Rod Ends in 2002 @ 110K
AC bearing went in 2006
A few Coil on plugs 2005
Odometer readout issue started around 2003 (think I read a post hear about someone that fixed theirs.)
Yep, crack on the Door Otr. @ belt line.
Muffler minimal patch last year and your standard maintenace type items.
Currently have the check engine light and ABS light on. The CEL is for a "insuffient flow" code.
I'm assuming the ABS light is for a bad sensor. Both of these I need to fix but haven't made them a priority. (The CEL will go back off during long trips.)
Guess that's it...
Old Aug 4, 2008 | 08:47 PM
  #123
novsun88's Avatar
These are ford trucks... Our old work truck (93 F250 xcab long bed diesel) has 270K miles on original tranny and engine. Through some rigging was done to the glo plugs, and then theres the slight shaking ... its all original! Proper maintenance
Old Aug 8, 2008 | 11:45 AM
  #124
chossy's Avatar
I bought mine new Sept. 2000.
Somewhere in South Dakota in 2004.
It currently has 148,something with nothing major yet. It has a 5.4L V8. I'll be the first to admit I haven't taken the best care of it. Shes been rode hard and put up wet many times. Most are highway miles, but it has its fair share of 4wd roads and mud holes too. I normally change the oil every 5000 miles.
With the price of gas and a change in my work and lifestyle I don't drive it as much as I would like anymore. The rest of the truck will probably rust out before the engine dies at the rate it is going.
Old Aug 8, 2008 | 02:19 PM
  #125
x_sgs_x's Avatar
I got my truck in late 07 with 54k now it has 70k lol
Old Aug 10, 2008 | 03:37 PM
  #126
4.2L_Guy's Avatar
i got mine 3 years ago... and have put 68000 on it... lol
Old Aug 10, 2008 | 09:37 PM
  #127
tom-rad's Avatar
'99 4X4 with 120k
Bought new March '99.....other than two freeze plugs seeping (hope the Bar's Leaks fixes it), it's been very reliable. Original plugs, still starts right up. Original battery, too.
Old Aug 11, 2008 | 09:58 AM
  #128
EaglesGreen's Avatar
'97 4WD Std cab. 155,000. Finally have a problem. &^% ECU/emissions failure. Seems to be a common issue.
Fly Eagles Fly
Old Aug 16, 2008 | 01:05 AM
  #129
chris3323's Avatar
'97, 4.2L, 166K....original clutch!
Old Aug 17, 2008 | 08:50 AM
  #130
horsegent's Avatar
97 4.6 Reg cab - farm truck.. It just turned past 400000 Km - around 250000 miles. I have replaced the TPS and have to do it again soon. No other problems.. and I'm still on the original wires. Dirt roads = Rust.
Old Aug 17, 2008 | 01:11 PM
  #131
x_sgs_x's Avatar
I guess that trucks never seen 60mph.
Old Aug 17, 2008 | 07:56 PM
  #132
GPHESQ's Avatar
2001 Ford F150XL V6 4.2L 205,000 miles.
Crankshaft oil seal needs replacing, got me a leak there and a minor leak from valve cover. Need to replace both upper ball joints, flush the coolant, change the brake fluid.
Other than that, I put 500 miles on it every week. !! Still runs and looks good for its age and current mileage. Contemplating selling it, but doubt will get any takers.
Old Aug 18, 2008 | 12:41 PM
  #133
chris3323's Avatar
strangely enough it has. i havent been to kind to it.
Old Aug 18, 2008 | 03:10 PM
  #134
BrewMan65's Avatar
1997 F150XL V6 4.2L 256CID (5 SPD Manual) - 140,000 miles.
Original clutch, no leaks or current issues. No major issues with this truck through its life other than standard recall work. It has had a construction barrel slung at it, a deer that may have made it (not sure) and countless small furry animals that dare to venture across the roadway. Front brakes and wheel bearing changed once. Rear are still original, but need replacing. Built FORD tough!
Old Nov 11, 2008 | 02:55 PM
  #135
cantrma's Avatar
I have 280,000 miles on a '97 scab 4.2 v6 stick. I've changed the plugs twice and the oil about every 10,000. Until the rear main seal started leaking a little, it never used a quart of oil in a 10,000 oil change. Original O2 sensors, get about 20-22mpg with a 3.08 rear end out of an automatic.
