4R70W replacement transmission tailshaft housing 1” longer.
I know I seen a thread pertaining to this topic but cannot seem to locate it at the moment. I don’t recall there being a definitive answer. I am in the process of replacing a transmission for a new customer in his 2000 F150 2WD. His 4R70W went from slow to engage out of park or neutral to not engaging at all. I dislike most inexperienced people do and performed the basic tranny service (new filter, new gasket, clean the magnet, check for brass/metal flakes in the pan, and 5 quarts of new Mercon V. You guessed it , it made it worse for draining out the old fluid which had disintegrated clutch material in it and adding new clean fluid which washed away even more of the friction material away. So I hunted around and via FaceBook market found a recently rebuilt 4R70W replacement for under $500.00 and 2 hours away. Everything looked the same but when I got it back to the shop and was double checking everything that’s when I happened to measure the tail-shaft housing and found the replacement to be an inch longer. I went ahead and installed it and tried to install the drive line and of coarse it was too long. I took some more measurements making sure there wasn’t a flat spot on the shaft or not enough splines stopping the slip yolk from going all the way in, there wasn’t it was just bottoming out so I cut 1” of the slip yolk of said drive line put a chamfered edge to it , cleaned up the splines and installed it with no other problems .
on
The following users liked this post:
We don't know that he's a redneck. We have no established facts in evidence. Only by his own admission that he believes transmission service causes transmission failure; as opposed to other people who believe in regular service intervals to maintain the transmission. We also know that he shops on Facebook. But that would not indicate that Facebook is his source of fake news. We also know that he had no prior knowledge of the different configurations for the same transmission.
If I were a redneck, I would be a little sensitive and offended.
Then could we perhaps, say, that the term "redneck" is more of a term of endearment? That it conveys a special affection? Maybe even hinting at a fraternal connection?
Forgive me. I am not cool. I just don't know the hipster slang. I don't speak jive.
I don't know how that slip yoke went in there, but I do know this. There isn't enough clearance between the back of the output shaft and the bottom of the slip yoke bore now.
So, what does that matter?
It REALLY matters. Anyone doing this or the truck owner won't likely notice it initially, but the transmission will. As the suspension moves, the slip yoke needs to have proper travel to slip. That's the whole point of a slip yoke. Otherwise there would be a u-joint connection there. The effective length of the driveshaft changes quite a bit as the suspension moves. Without proper clearance the slip yoke ends up hammering on the end of the output shaft. This hammering forces the output shaft to move forward and beats the living hell out of the transmission internals.
This is one case where you REALLY don't want to do any form of (insert derogatory adjective of your choice here) engineering. There are a whole lot of terms for people who do stuff like that. Most start with a d, j or m, are often preceded with a word starting with f. None of them are at all flattering but are very deserved because people who do stuff like this hurt other people and are proud of themselves for doing what they do.
D
D
In other words, what Darrin is referring to is no different than cutting a PTO shaft to fit a tractor and implement.
If the shaft is too long, and it fits when the implement is on the ground, then you go to lift the 3pt arms, it shaft needs to slide a bit to retract. If not, it doesn't have any place to go, and will wind up either taking out a transmission or the implement gear case or both. I see this problem with a lot of folks with subcompact tractors that have no clue or didn't read the instructions.
Same thing that goes on with a slip yoke, it allows for travel with the suspension so the shaft isn't ramming itself into the tranny or bevel gear case (rear diff).
In this case, you need to make sure everything is correct... if not you'll need the correct driveshaft and slip yoke assembly.
D
You, Sir, are politically correct, and a gentleman.
The rest of us would have just used the swear words.
Either do it right or don't do it. If, for whatever reason, you cant then go find something that you can do that doesn't do harm to others. Maybe apply to be a Walmart greeter or something, because buddy, this isn't your gig.
I actually cringed reading what he did to a customer's car.
Fbird
well he b gettn er done!.....
I once looked under a girlfriend's car because she was complaining that the car was old, and leaking oil on her garage floor. I looked and found Loctite blue smeared all over the oil drain plug and around it. The drain plug was rounded down. I finally got the drain plug off by using an impact gun and a lug nut lock removal socket. The drain plug gasket was deformed, and also had Loctite smeared all over it. I got a new drain plug washer, and a new drain plug.
Car was only 6 years old, and maintained since new, by 1 shop. Owner was a friend of the girl's family. Shop owner told her that's what happens over time, and that all cars eventually leaked. I spoke to him. He explained that the Loctite slowed down the oil leak. Without it, the car would lose a quart a week. His guys would use an air tool so that they can get the plug on tighter, which also meant that it took that much more torque to get it off at the next oil change. That's why the head was rounded down. I had to ask the guy why his techs never changed the washer. His reply was, "this isn't a dealership, how is an independent shop suppose to have all of those different washers for different cars?"
I took a quick glance at her invoices, since she kept every receipt in a folder. He was a friend of the family. He was trying to save her a little money. Always gave her a 10% discount. Dude really took $2 off the $19.95 oil change. All the oil change tickets, every 3 months or 3,000 miles, showed 4 quarts of 10W-40. Her little Honda uses 4.5 quarts of 5W-20. So he used the wrong oil weight, and not enough of it.
he be gettn her done
1” update
For any and all self proclaimed masters of mechanical engineering and other people’s of popular hydrodynamic principles. The afore mentioned 1” onsite modification has had no ill effects upon the performance or lack there of in any way shape or form and the Spanish speaking amigo can be seen driving the vehicle in question with smile upon his face on a daily basis. For the amount he paid out of pocket for a professional technician to diagnose, remove, locate, and install a replacement transmission on site all the while avoiding a tow bill ,shop fees and parts markup why the choice is so in your face and easy to comprehend that even the most prominent professors of propulsion power systems would gladly have made the same choice as Louis the lucky Latino .
Definition of “hack”
informal
: a usually simple and clever tip or technique for accomplishing some familiar task more easily and efficiently "hacks," as they are known, are all about eliminating life's manifold frustrations in simple and deliciously clever ways. The best involve tricks that are free, efficient and stunningly obvious
