Downshifting an automatic?
Old Jul 6, 2010 | 01:38 AM
FX2 fst for you's Avatar
Good idea or bad? I just got new exhaust and it sounds great when Im coming to a stop to turn off overdrive and throw it in to second and let her rumble. Anyone think my silly antics are hurting my tranny? Im driving a 2008 FX2 any thoughts are appreciated
Old Jul 9, 2010 | 01:57 AM
no opinons?
Old Jul 9, 2010 | 03:16 AM
tbear853's Avatar
Originally Posted by FX2 fst for you
no opinons?
As long as you aren't pulling her into 2nd at high speed all the time, I see no harm.
I often drop her out of OD when coming into a 45 or slower zone as slowing down, steep down grade I might ease the lever back into 2nd as my next step if I'm under 45 or 50.
I do not shift from OD to 2nd however, not unless I go to 3rd first doing it in two steps.
Old Jul 10, 2010 | 07:58 PM
I'm up here in Canada, can I assume that those speeds are KPH? That is all good news as I think I already drive the way you explained. Thanks for the info
Old Jul 10, 2010 | 08:41 PM
avfrog's Avatar
I also hit the o/d off button all the time, but I don't shift into 2nd.
Old Jul 11, 2010 | 12:21 PM
The computer will protect you - if a downshift would be out of parameters it won't downshift.
Old Jul 11, 2010 | 04:57 PM
O/D is ok to disable, but down shifting gears isn't a real good thing to make a habit of.
Old Jul 11, 2010 | 05:07 PM
Tumba's Avatar
Just remember, when you put one in 2, it does not down shift to first when taking off from a stop. It stays in second. That is hard on your transmission.
I don't know why Fords are like that. But other brands I've driven will downshift.
Old Jul 11, 2010 | 05:16 PM
mlamprey's Avatar
You could drive like an mature adult instead of a immature 16 yr old, then you wouldn't have this question or concern.
Sorry, I couldn't resist. Sometimes a thread or a post is just begging for a sarcastic or a truthful reply.
Old Jul 11, 2010 | 10:34 PM
Mark Kovalsky's Avatar
The transmission has been engineered to do that without damage. It isn't hard on the transmission.
To reduce the tendency to spin the wheels on low traction surfaces, such as snow and ice.
Old Jul 11, 2010 | 10:51 PM
Tumba's Avatar
It isn't hard on the clutch packs to start from a stop in second gear?
I just always thought it was strange for Ford to engineer them that way.
It also seems more likely it would break traction, having a higher gear ratio in second, and less friction on the slick surface.
Old Jul 11, 2010 | 11:39 PM
Ford automatics have had 2nd gear start since their first 3 speed automatic back in the 50's. It makes a difference on slippery surfaces, the power application is smoother and less sensitive.
Old Jul 12, 2010 | 01:34 AM
Never! I'll be the 16 year old guy downshifting to second and street racing with your kid on a street with a cul de sac! Just kidding
Usually I downshift to second on steeper hills or if persay a cute girl may be walking by my hand might slip and hit the stick down in to second. MAYBE. I always shift it back when I stop and try to avoid doing it at such a time it would cause me to have to shift to drive while I'm on the gas. Who knows maybe one day I may grow up but I hope not
Last edited by FX2 fst for you; Jul 12, 2010 at 01:37 AM. Reason: blame it on the "quote"
Old Jul 12, 2010 | 06:38 AM
mlamprey's Avatar
Which stick are you talking about
Old Jul 12, 2010 | 09:00 PM
4wd150's Avatar
. and to the OP, youre only young once might as well live it up, im only 19 and do the same kinda crap so dont feel bad lol
