Downshifting an automatic?
Old Jul 13, 2010 | 01:50 AM
FX2 fst for you's Avatar
Originally Posted by 4wd150
. and to the OP, youre only young once might as well live it up, im only 19 and do the same kinda crap so dont feel bad lol
Oh my Im almost thirty and when someone says OP I kinda stop and think.
Old Jul 13, 2010 | 11:06 PM
Mark Kovalsky's Avatar
Originally Posted by Tumba
It isn't hard on the clutch packs to start from a stop in second gear?
The transmission was designed to be able to do that without any damage.
It also seems more likely it would break traction, having a higher gear ratio in second, and less friction on the slick surface.
You've got it backwards. Starting in a higher gear makes it less likely to break traction. If it were more likely the trans would start in overdrive instead of first gear.
