Bumper Tow Ball
Bumper Tow Ball
I was Wondering how much can the Bumper tow? I have a ball on the bumper and all i want to tow is a small 5 by 8 or so trailer with wood in it for camping. Would the bumber be ok with that kinda load? BTW i have a V-6 unfortunatly.
Most factory bumpers are rated at 500# tongue weight.
This means that loaded correctly you should be able to tow 2500#'s
With the height not being adjustable you may not be able to load your trailer correctly...level and weight distributed...so your payload will be less.
If you plan to tow more than once...invest in a reciever as it will also give you a little more clearance when turning to prevent jack-knifing and denting your bumper.
Recievers ratings:
Class I
200# tongue weight---2000# total trailer weight
small reciever 3/4" ball shank
Class II
350# tongue weight---3500# total trailer weight
Class III
500# tongue weight---5000# total trailer weight
2" square tube reciever 1" ball shank
Class IV
900# tongue weight---10,000# total trailer weight
2" square tube reciever with re-enforcement ring 1" or 1.25" ball shank
Class IV with a V endorcement
1200# tongue weight---12,000# total trailer weight
2.5" square tube with re-enforcement ring 1.25" ball shank
Class V
1500# tongue weight---15,000# total trailer weight
2.5" square tube with 1.25" ball shank or Pintle
Recievers ratings:
Class I
Class II
Class III
Class IV
Class V
Originally Posted by agutowski3388
...all i want to tow is a small 5 by 8 or so trailer with wood in it for camping....
It does not increase your weight towing ability.
It does allow you to level out those little trailers.
That is the biggest problem towing from the bumper, small trailers have their tongue up in the air and it makes them wag down the road.
A box hitch mounts under your bumper and allows you to use a drop drawbar just as if you had a real hitch.
PROs
cheap
levels little trailers
CONs
you are still towing from the bumper
http://www.northerntool.com/webapp/w...70_43576_43576
The weight is fine for a bumper. almost any sinagle axle trailer will be fine on the bumper. The height is usually the problem for most trailers, especially small ones. For that, the hitch box or receiver is the better way to go.
My 97' reg cab with 4.6L has a bumper tow rating of 5,000lbs with a max tongue weight of 500lbs. Those numbers are stamped on the bumper aswell as in my owners manuel. I use to tow with ball mounted to bumper but as has been stated while turning tightly I got a few small dents from the trailer hitting. Using a receiver hitch stopped that.
It's a freaking 5x8 trailer. You'll break the trailer or blow out the tires from the too much firewood before you mess up your bumper. Heck all the pickups my dad had when I was growing up all had ***** on the bumper. He towed 6500lbs of cattle plus the weight of the trailer with them and never broke a thing. Granted the bumper wasn't one of these fllimsy factor bumpers.
Originally Posted by KDOTengineer
It's a freaking 5x8 trailer....
here is one for cheap it's off of a 97 but in florida i don't know where you live at or what year your truck is but he said he could ship... http://cgi.ebay.com/ebaymotors/97-Fo...87155621QQrdZ1
Yes, it is worth getting the receiver & ball mount.
