coil spring spacers for 97-03 f150 2wd
my question is i see them on ebay in 1" / 2"/2.5"/&3" is the 2" too much too add to my 6.5 spring tech lift? im also adding a 3" body lift & 2-3" add a leafs. i just have no clue on how bad those spacers are and what they will do to my ball joints and ability to align the front end. thanks in advance goal is not to rub my freshly painted piaa valance with 37 - 13.50 - 20 mud grapplers of toyo open country m/t's
man thats a bummer. dont know if i can clear the 37's then with out buyin new rims with less off set but i really like the lip on them. i have the 3" body already just dont want to trim the piaa valance. it was hard to squeeze those leaf coils in so i can see where u could be right. man im bummed.
From what I've seen, you can run a 2". The springtech UCA's bring the upper angles back to factory, so it would be like adding a 2" level to a stock truck. You might not have perfect angles, but it will still be decent. The springtech UCA's actually caused my truck to have some slight positive camber (more lift was needed to properly align), so when I actually do get around to finally doing this I'm going to run 2" spacers over the 1.5" because of that.
Deno did this to his old truck, you might want to ask him.
