Total Chaos uca?
Total Chaos uca?
My ball joints have to be replaced and instead of stock I was looking at the total chaos units. Can these be used with a leveling kit to get rid of the severe angles of the balljoints or is that not what they are made for? Now on their website it says they can be used with different brands of coilovers to get 2" of lift. Would that be the max lift you could use with a leveling kit or would it be ok to use a 2.5 or even a 3" kit? And is it the same as the camburg uca's because with there kit you have to use a rim with a 4.75" bs? Or can i use the stock rim? I just cant see spending all that money on the stock uca to have it wear out again cause of the leveling kit.
In reference to the OP, this is directly from their site, does this only apply to setups using shocks w/reservoir or does this also apply to the wheel and tire:
EDIT: I do see pics on their site of trucks running OEM wheels, not sure if there is a spacer though.
Aftermarket wheels required to avoid the tire contacting the reservoir hose or wheel spacers if larger tires are installed on factory wheels. 4.5" or less backspacing required on all wheels to avoid contact.
huh? I wish they would clarify a little more. And ya i seen pics of stock rims too so idk what there doing.
