Total Chaos upper control arms
Old Jun 10, 2007 | 05:53 PM
fx4f150guy's Avatar
Hey guys ive been reading about these Total Chaos arms and I was wondering if I would be able to use them on the Rize 8" lift? It says you run them with King coilovers which I was already planning on doing with my lift. So let me know what yall think! thanks
Old Jun 10, 2007 | 10:00 PM
nuclearthreat54's Avatar
Well I THINK you can run them. It says so right there in your post.
Old Jun 10, 2007 | 10:15 PM
ThumperMX113's Avatar
I don't see a problem with running them.
Old Jun 10, 2007 | 11:35 PM
04procompLARIAT's Avatar
You can run them with anything you want as long as the balljoint angle isnt to gnarly. I have them with my procomp 8 inch kit.
Old Jun 11, 2007 | 12:01 AM
BestNTx's Avatar
You say you have an 8 inch kit? is that because you cranked your coilovers 2inches?
Old Jun 11, 2007 | 12:11 AM
patshea098's Avatar
i think its cause he wantdd the coilovers and he had to change to the 4X4 Spindle to do so or something. but im 99% sure he put a 4X4 spindle on from the 2WD one.
Old Jun 11, 2007 | 02:19 AM
fx4f150guy's Avatar
Thats awesome... I think ill have to get some as soon as i get more $$$$
Can you tell a difference with the ride or handling? or anything at all?
Old Jun 11, 2007 | 03:16 AM
Haha...I have the 4wd coilover which is a little longer than the 2wd and has stiffer coils so I got about 2 extra inches over the 6 inch 2wd coilover. I have had no problems and really cant tell any difference in the ride. Its just peace of mind that I have a huge uniball instead of a weak stock balljoint.
Old Jun 11, 2007 | 10:29 AM
extremeethan's Avatar
Not to start a flame war but really the uniball arms are only a little better then a regular ball joint in terms of not poping out. Uniballs are replacable meaning they can pop out to be replaced. In the set up like the UCA, a single shear without a safety washer how ever unlikely could still pop out with about the same likelyhood of a good ball joint poping out. Both poping out are rare and normally only happen on warn joints. Dont get me wrong I want a set but a lot for looks and then because they will wear out a lot slower then a regular ball joint. A simple safety washer could make them bullet proof but not one arm company includes them
Old Jun 11, 2007 | 11:17 AM
i.ride.suzuki's Avatar
Camburg has a set listed on their page for $550
Old Jun 11, 2007 | 05:13 PM
So eethan why do all the race trucks have uniballs if stock balljoints are just as strong?
Old Jun 11, 2007 | 05:22 PM
captain morgan8's Avatar
looks like I'm gonna be gettin some here in the next couple of weeks
there's a $650 package you use with the King coilovers, and a $770 package for stock coilovers
http://www.polyperformance.com/shop/...productid=2214
Old Jun 11, 2007 | 05:34 PM
You read it wrong, Uniballs are better but only when used in the right way like in a double shear set up or at least with a safety washer to prevent poping them out. Uniballs are better no doubt, but I havent heard of anyone really poping a ball joint out, its always I knew a guy that saw a guy pop one. My above post was usless because most here will never use their truck hard enough to worry about poping either a ball joint or uniball out.
Old Jun 11, 2007 | 05:37 PM
fx4f150guy's Avatar
Yeah I think im going to get a pair too... ill prob need them if I end up running 38's or 40's. Plus they would be great to have on a stock ride. I wish we could still do the group buy for kings so I could save a little bit of money.
Old Jun 11, 2007 | 05:47 PM
I have seen worn out balljoint due to oversized tires all the time....these are just good to have if you have 35 inch tires or bigger.
