Sponsored by: CARiD
suspension fund
Old Apr 10, 2011 | 10:36 AM
  #61
06yz250f's Avatar
think of a circle w/ radius diameter 10. your radius is 5. now think of a larger circle diameter 12, the radius is 6. the radius only increased 1 while the diameter increased 2.
does that make any sense?
Old Apr 10, 2011 | 12:26 PM
  #62
hardrock3742's Avatar
hah yeah, i understand now. darn
I wish there was a way to see what my truck would look like after the lift
Old Apr 11, 2011 | 09:55 PM
  #63
I think I want to get the nitto mud grapplers instead. I honestly dont care about the noise. And Im reading reviews that are saying ppl are getting 30k + miles on them...any advice?
oh and will they fit on my truck if I get a 6" lift and the 2" bilstien shocks for the front? will they rub?
Old Apr 11, 2011 | 10:16 PM
  #64
06yz250f's Avatar
you might get 30k+ miles if you run them down to slicks. if you want 35's it'd be wise to go for the 2" extra of lift depending on your wheel choice.
Old Apr 11, 2011 | 10:22 PM
  #65
what do you mean by that last part? I plan on putting them on my stock wheels first(17x9 i think) or just getting 17x9 aftermarket wheels with some offset to get 2-3 inches to stick out
Old Apr 11, 2011 | 10:44 PM
  #66
06yz250f's Avatar
the farther the wheel/tire combo stick out generally it means more rubbing possibility.
if you are on stock wheels with 6" of lift then you should be fine. verify the lift kit you get will fit stock wheels. if you get aftermarket wheels the lift manufacturers specs are a good guide line on wheel specs. tire selection also plays into rubbing. for example a Mud terrain will have deeper side lugs than an all terrain so chances of rubbing on something increase.
Old Apr 11, 2011 | 10:49 PM
  #67
oh, i figured that the farther the tires stuck out the less they would rub because they would be farther from the wheel well.
Old Apr 12, 2011 | 01:23 PM
  #68
Randyl9ll's Avatar
The stock 17's are 7.5" wide. I had 12.5" wide tires mounted on them for a while and got some weird tire wear.
Old Apr 12, 2011 | 01:24 PM
  #69
thanks for the heads up!
Old Apr 22, 2011 | 03:52 PM
  #70
UPDATE.
So I was planning on putting aside a couple hundred every month...but in the past 2 weeks ive put aside $700 lol. Im pretty sure Im going to get the fabtech kit. then gunna get these wheels at -12 offset and wrap them with 35x12.5x17 nitto trail grapplers.
If i can sell this sound system i will be at $1000. then I should be getting about $1000 as a downpayment from selling my stang.
ill keep you guys updated
Just went up to discount tire. He said he would sell me the tires and wheels for $1500. and it turns out I cant get them untill I pay them off all the way :/
Old May 3, 2011 | 10:47 AM
  #71
Just bought the 6" skyjacker kit with hydroshocks
Old Jun 10, 2011 | 04:50 PM
  #72
for anyone who is interested I just thought id throw out an update. I would have had it done by now but I had to keep $ set aside for school. anyways, I should have enough money to complete my process in about 2 weeks! im so excited!
Old Jun 13, 2011 | 04:29 PM
  #73
Randyl9ll's Avatar
Awesome man! I look forward to seeing it all put together.
