softer ride, opinions wanted
In your opinion or from experience or just suggestions in general, what could I do to get a softer ride or feel? I've got the bilsteins up front and the procomp shocks that came with the lift in the back. I have heard the UCA's help out and I've heard the same about coilovers. Just looking for people's opinions and suggestions on whatever brands or any ideas.
Thanks Wandell, that was the problem. The 35's were at 50 psi, lowered them to about 42 and rides smooth as glass.
I don't think UCAs are going to help with the ride at all. The joint is much stiffer than the stock UCA so if anything it should be a harsher ride. I'd look into getting something custom valved like Kings, SAWs, Camburgs. Do you need to correct the front, rear, or both?
I'm running 37" tires and mine is smooth. I had to play around with my air pressure. That makes a bigger difference than you might think.
Also, I was running bad tires. I changed to the Toyo MT's. That made a big change.
The thing that really dialed everything in was the rims. I changed out my rims and the new ones were better rounded. That was huge.
