SuperCrew
Headlight Bulb Removal
Old Apr 11, 2003 | 08:35 AM
Fireman Dave's Avatar
Question Headlight Bulb Removal
Been lurking quite a while, and just got my SCREW last week. I like it MUCH better than my 98 EB Expedition. My question is regarding headlight removal. I intend to install the silverstars this weekend, and the RF headlight bulb can be accesed without removing anything. However the L side is another story. I read somewhere that you pull up in the two levers near the core support to remove the headlight assy. When I pull up on the levers, the assy. seems to become loosened, but it still does not come out. Would it just be easier to remove the coolant tank?
TIA for your input, I have already purchased several items based on this forum, great info here.
Dave
Old Apr 11, 2003 | 09:15 AM
ReelWork's Avatar
Removal...
The two tabs you pull up are the only two tabs and you might want to look down so you can see where the slot openings are in relation to the grommet that comes off the headlamp assembly that holds it in place. Sometimes they don't want to come popping right out so you may have to give it a light push from behind or something...
Later,
Chris (ReelWork)
Old Apr 11, 2003 | 08:25 PM
THall's Avatar
I just did the same job and went thru the same learning curve
No, you don't have to remove anything. You just pull up on the two tabs and like ReelWork said, look down inside where the tabs are moving to make sure that the headlight is released and then using your fingers push forward on the place where the wire connector connects to the bulb.
Also, The Omni-Present RockPick (I don't know how he spends so much time on this forum) posted a really good comment in another forum about removing the signal lights when replacing the headlights. Ya, Ya, I thought . . . I will just pay attention to detail, use my incredibly developed mechanical skills, and skip that recommendation.
It is just one bolt on the top of the signal light assembly to remove the signal lights while replacing the headlights which is what you do to plug in your new SilverStars. DO remove those signal lights! It is sooo much easier and will save you sooo much time and agrivation.
Tom Hall
Old Apr 11, 2003 | 08:32 PM
Rockpick's Avatar
Moderator &
Ahh Dave, if you had posted about two weeks ago, I could've just come by and pulled your headlights out while I was doing work up in South Bend over off of Orange Street (adhesives manufacturer)...
Not sure if anyone's mentioned this but, I recommend that you remove the corner lamps before reinstalling the housings. It'll make your job MUCH easier because lining up those little tabs can be a booger sometimes.
RP
Old Apr 11, 2003 | 09:09 PM
THall's Avatar
Here is a bit of clarification -
Remove the signal light assembly screw. Then pull the signal light assembly forward to remove it.
Then pull up on the headlight tabs and look to ensure that the assembly can move forward. Then push headlight assembly forward. Removing the signal light assembly will save you a bunch of time and agrivation. This tip is originally from the Omni-Present RockPick.
Tom Hall
Old Apr 11, 2003 | 09:47 PM
Jaguar's Avatar
Thall/Rockpick,
Thanks for the tip(s). I think I will do the same when I install my Xenarcs this weekend!
Old Apr 14, 2003 | 08:51 AM
Thanks for all the great replies folks! The silverstars are going in the fogs and the headlights this week. I didn't know about removing the corner lights, great info. When I pulled the tabs "experimenting" the other day, It almost seemed like I didn't get them re engaged properly. The headlight assys seemed rather loose, so I will look into that more closely. Rockpick, next time you are gonna be in town drop me an Email and I'll meet ya somewhere.
Old Apr 14, 2003 | 07:34 PM
Rockpick's Avatar
Moderator &
Re: Here is a bit of clarification -
Originally posted by THall
...This tip is originally from the Omni-Present RockPick.
Omni?
Old Apr 14, 2003 | 07:37 PM
Rockpick's Avatar
Moderator &
Dave,
Not sure when the next time will be as it's not looking like we'll be continuing with that particular job for a while but, if I am up there, I'll give you a yell.
Thanks for the offer!!
Ever eaten at Politos over in Mishawaka next door to Outback? Best rigatoni and vodka sauce on the face of the earth!!!!! I wish I had some of that right now...
RP
Old Apr 16, 2003 | 02:23 AM
THall's Avatar
Re: Re: Here is a bit of clarification -
Originally posted by RockPick
Omni?
Ya, as in almost 4000 posts!!! It is amazing how many threads you touch and how much time you spend on this forum. Actually I thought I would get a rise out of you before this post with that comment as I have used it before. Gee, I have been feeling all lonely and remorsefull about not getting a rise out of you before this.
Go ahead this one should be post number 3940!
Tom Hall
