Went To The Track Today
#46
I'm also tempted to add a sexy CAI but I was told that I'd lose performance by removing doing so
#47
#51
Well here's the cracked factory flex plate. Crack measures 4.75" long. Impressive to say the least. A lot of difference in the the new one verses the old. For starters the new one is thicker, welded on both sides, has 9 welds on each side verses stock which has just 8 on one side, and it's platinum coated so it won't rust. Plus it meets SFI Spec 29.1.
Thanks again to RobertP for identifing this by just the sound coming through my cell phone and then sending me a link to this new one.
![](https://www.f150online.com/forums/members/twinskrewd-albums-random-picture195801-cracked-stock-flexplate.jpg)
#53
#54
Thanks MeanGene. Hope to improve upon the 12.4 run. We shall see.
As for the flywheel, the PRW part went in without a hitch. I'm sore from head to toe but it was worth it. Truck is back to normal and I hope to meet RobertP in Fayetteville in a few weeks to do some racing. Hope the temps will be good.
For those interested the PRW flex-plate weighs 7.9lbs, that's 1.9 lbs more then the stock unit. It is nearly twice as thick at 4mm verses the stock one at 2.38mm. It's a stout part for sure. Cold rolled premium steel, 9 robotic welds on each side of the ring gear (stock is 8 on 1 side), and it's platinum coated to prevent rust. Not bad for a $79 part.
#55
![devil](https://www.f150online.com/forums/images/smilies/devil.gif)
This has always resulted in better times.
#56
#57
2 newbie questions about the track
-how do you know when to floor it? half a sec after orange or at solid green?
-do you floor the pedal 100% or 75% then floor 100%? I wonder how the street tires don't loose traction, I know there is a quick burnout before but is that really enough?
Running street tires will result in slower 60' times but you can still make good time with them. It's just really tough to and it takes a few runs to figure out what works. As you mentioned feathering the throttle at some precentage until you have enough traction to floor it. I ran some 13.2 and 13.3's with my street tires on 9 psi of boost. By comparison the slicks got me a 12.9 on 9psi.
Here's a video focused on the tires as I ripped a 1.7 60' and a 12.7 run.
And in this video you will see me floor it on the third yellow
#59
#60
A/C PULLEY (YB-542) $53.02
Alternator pulley F65Z-10344-AA (GP-720) $13.97
Power steering pulley XL3Z-3A733-AA $42.08
Tensioner 1L3Z-6B209-AA $46.30
Crank pulley XL1Z-6312-CA
Idler pulley F65Z-8678-AAA (YS-250). $33.43
Water pump pulley F6TZ-8509-AA $14.55
