autometer boostguage install questions
i am installing my autometer boost/vac guage and I am unsure of the best manifold vaccuum source i need to use for the hollow tube????
this is how i have it tied in now:
or should It go here:
just want to ensure I have it hooked up right. just want to see the vacume now VS later with the boost
built5.4 where did you tie in the power and ground wiring for the lights??
here's what it looks like after dark:
pull out your light switch and tap into the #12 and #6 wires should be a brown and the other one black
black is the ground and the brown is the power relay so your boost guage light works off of your light switch
