New mods
Old Mar 29, 2014 | 03:31 PM
  #361
01 gt f150's Avatar
Crappy weather today. Been out looking at the new shoes. I just called the tire joint because I want a little wider tire. so they just ordered 295/40/20's for me with no grief. I've rolled an entire 1 mile on these and the side walls have been bugging me. I like a blocked side wall with no stretch. Hard earned money means get exactly what you want and don't settle. The pics show the width issue I'm having. The tread is not as wide as the rim.
Old Mar 29, 2014 | 04:10 PM
  #362
They were as wide as the last ones on a 10" rim too, weren't they? Less sidewall though, so that's probably why.
Old Apr 2, 2014 | 12:15 AM
  #363
01 gt f150's Avatar
The lightning rims have 295/45/18's Going to a 295/40/20 will put me back where I was on width.
Old Apr 2, 2014 | 02:38 AM
  #364
Oh, thought they both had 275s.
Old Apr 3, 2014 | 06:34 PM
  #365
01 gt f150's Avatar
Got the even newer shoes today. 295/40/20 Toyo Proxie ST II's. Looks a crap load better.
Had the alignment checked to be sure and it is dialed in. All in all a good day!
[IMG][/IMG]
Old Apr 3, 2014 | 08:18 PM
  #366
Does indeed look better!
Old Apr 3, 2014 | 10:10 PM
  #367
01 gt f150's Avatar
Thanks Kent
Old Apr 9, 2014 | 12:00 AM
  #368
01 gt f150's Avatar
Got a couple of pics today. People have asked what the new tires look like from
the back. Just happened to catch a bit of the pearl in one of them. Still waiting of the custom seat covers. Shouldn't be to much longer... getting anxious.
Old Apr 18, 2014 | 10:11 PM
  #369
01 gt f150's Avatar
I'm in the process of another audio revamp. I didn't like the way the current one was sounding. I have picky ears and have done competitions in the past. I just received my new amps and bass ****. I went back to my original set up from back in the day with just newer versions. Rockford Fosgate P1000x1bd on the lows and a Rockford Fosgate P600x4 to handle mids and highs.
Both birth sheets are impressive and am looking forward to hearing these things get down. I may be replacing subs so the Ohms works with the amp better. I will decide once I hear these with the new amps. Keep in mind the numbers at the bottum right of the birth sheets is the rated RMS power, not max.
Old Apr 18, 2014 | 11:27 PM
  #370
J00F150's Avatar
What does the rear seat look like in the truck since its out of a Expy?
Old Apr 19, 2014 | 11:39 AM
  #371
01 gt f150's Avatar
This pic is while working on the install. I need to get more pics when in gets back from the paint shop detail.
Old Apr 19, 2014 | 07:04 PM
  #372
J00F150's Avatar
That is cool, any special brackets or anything?
Old Apr 20, 2014 | 02:21 AM
  #373
01 gt f150's Avatar
***** and fender washers..lol Shallow uni-strut and some earthquake support brackets from work to configure the front part.
Painted everything flat black for O.E. appearence.
Old Apr 20, 2014 | 03:19 PM
  #374
01 gt f150's Avatar
Cleaned up the wheel wells, repainted everything and reworked the spindles and made custom dust caps to shorten things up so the
wheel center caps would fit.
Old Apr 20, 2014 | 03:38 PM
  #375
20x10s right?
