might be going lower!
Old Oct 10, 2011 | 10:48 PM
  #91
c_ulater's Avatar
What's the story with the car on the trailer?
Old Oct 10, 2011 | 11:14 PM
  #92
azmidget91's Avatar
Originally Posted by bankrpt
Just fyi a 255/45/20 is 29.1" and a 265/35/22 is 29.3" the 255/50/20 is 30.1"
And my 285/35/22's are 29.8
Old Oct 10, 2011 | 11:18 PM
  #93
azmidget91's Avatar
Bought it because it had a 87 thunderbird turbo coupe engine in it that I wanted for my 32 ford. Bought it for $800, took the engine and trans out, kept the drag wheels it came with and sold it for $750
engine in the pinto
in the 32
Old Oct 10, 2011 | 11:20 PM
  #94
If you were closer i could give you a 3/32" tire for your spare in 255-50-20
Old Oct 10, 2011 | 11:22 PM
  #95
azmidget91's Avatar
Maybe if you give it a good push it will roll all the way
Old Oct 10, 2011 | 11:27 PM
  #96
bankrpt's Avatar
My bad some reason I thought you was running 265/35/22 also sorry
Old Oct 10, 2011 | 11:29 PM
  #97
azmidget91's Avatar
All good, I'm running the "big" tire
Old Oct 10, 2011 | 11:47 PM
  #98
yah i thought you was running too
Old Oct 11, 2011 | 08:46 PM
  #99
c_ulater's Avatar
Nice. That's going to be bad ***.
Old Nov 10, 2011 | 01:56 PM
  #100
azmidget91's Avatar
Just got another one of my wacky great ideas. I want the rear to be stiffer, dont want to go higher just stiffer. I was thinking of an add a leaf but hard to find one that only adds about an inch but stiffens it significantly since most that low of lift are the long leafs. So why not just add another leaf from the stock leafs. Shouldn't lift me too much but should stiffen it a bit. Not sure how much stiffer or higher though. Anyways off to find some stock leafs on craigslist.
Old Nov 10, 2011 | 07:11 PM
  #101
bankrpt's Avatar
What rear shocks you running or you can also take measurements of your shocks fully extended and collapsed and go to the parts store and get the coilover shock book and find one with the same measurements
Old Nov 11, 2011 | 10:29 AM
  #102
azmidget91's Avatar
Ground force 70064, they are air shocks, they lift the truck about an inch if needed but dont do much for stiffness. and I had some QA1 coilovers on there before and worked out well, but just don't want to go that route again.
Old Nov 11, 2011 | 01:33 PM
  #103
you could just put some really rusty shocks on it to stiffen it up
You'd be surprised what a quality shock will do for stiffness, my truck with new shocks in the front rides smoother, and less choppy. A good shock controls compression (jounce) stroke and rebound
Old Nov 11, 2011 | 01:50 PM
  #104
azmidget91's Avatar
Yeah the new shock I put on the rear really helped. I do think its about time for fronts I think they have about 80k on them, rears have about maybe 10k
Old Nov 11, 2011 | 01:51 PM
  #105
I recently did front shocks when i did my front rebuild, and it made the whole truck feel different, not just the rear.....
