might be going lower!
Old Aug 28, 2011 | 03:16 PM
  #76
c_ulater's Avatar
I really like the new stance
Old Aug 28, 2011 | 06:10 PM
  #77
azmidget91's Avatar
Front 4.5"
DJM 2.5 arms
Belltech 2" spindles
Rear 8"
DJM flip
2" shackles
3" notch
rides like stock, way too soft though, no bottoming out, very minimal tire rubbing, bending in the fender lip will fix. if it were stiffer i would go another inch
Old Aug 28, 2011 | 06:51 PM
  #78
bankrpt's Avatar
What shocks you running?
Old Aug 28, 2011 | 08:25 PM
  #79
jsvo5695's Avatar
Looks good.
Old Aug 29, 2011 | 12:12 AM
  #80
azmidget91's Avatar
oem replacment shocks from napa in the front, and ground force air shocks in the rear, they are made for a 5" drop and has a helper bag type of sleeve on it, and they are only about $50 on amazon
Old Sep 3, 2011 | 08:08 PM
  #81
That looks great!
Old Sep 3, 2011 | 08:19 PM
  #82
good job, finally as low as me
(as far as spare sitting on the curb)
Old Sep 4, 2011 | 12:22 AM
  #83
azmidget91's Avatar
Yeah, yesterday I noticed that I am slightly taller than my truck, really made my day. Especially since I am only 5'7"
Old Sep 4, 2011 | 10:36 AM
  #84
Old Sep 4, 2011 | 03:21 PM
  #85
c_ulater's Avatar
Must be nice.
Old Oct 6, 2011 | 07:20 PM
  #86
azmidget91's Avatar
Just noticed a spot where my tires have rubbed on the bed inside wheel well, while doing my rear brakes yesterday....not an issue at all but just to inform people, with a 3" notch my 29.8" tall tires hit my bed before the axle hits the frame.
Old Oct 6, 2011 | 08:52 PM
  #87
97madness's Avatar
You make me want a ridiculous static drop now too...
Time to get the hammer out and fix the rubbing issue lol
Old Oct 7, 2011 | 05:25 AM
  #88
jsvo5695's Avatar
I had a similar issue when i was running the 285/35. The only difference is i was rubbing on one side only. For some reason the axle was offset to the dr side by 1/4". I said something to the dealership and they said they had seen it before and have had no problems ......yet.
Old Oct 10, 2011 | 02:48 PM
  #89
azmidget91's Avatar
No mine were hitting the top of the tub not on the side
Did some towing this weekend
and here shows the air assist shocks (groundforce 70064)
Passenger side up
Passenger side down
Driver side down
Driver side up
Need to figure out why my truck is not sitting level in the rear...
Also need to pick up a spare tire from a Navigator since the ones that came with oem 20's have a 20" spare as well. That way I would have a spare to fit with the drop spindles. Also need a 255/50/20 tire to have (close to) the same diameter as my 22's and same width as my current spare so I can still (barely) fit on curbs
Old Oct 10, 2011 | 09:59 PM
  #90
bankrpt's Avatar
Just fyi a 255/45/20 is 29.1" and a 265/35/22 is 29.3" the 255/50/20 is 30.1"
