Let the redo begin!
Old Jul 24, 2011 | 06:23 PM
  #406
jsvo5695's Avatar
Nothing changed on my truck. What is hitting/rubbing. Did you get an alignmemt yet?
Old Jul 24, 2011 | 07:18 PM
  #407
bankrpt's Avatar
What's your offset on your wheels?
Old Jul 25, 2011 | 10:15 AM
  #408
azmidget91's Avatar
22x9.5 with 30mm offset
i cant see anything hitting or rubbing, and i didnt get an alignment, it is very close to where it needs to be with just swapping the spindles. but i will probably do it next week, sucks having a real job that i cant just take the day off to go work on my truck...
Old Jul 25, 2011 | 12:54 PM
  #409
jsvo5695's Avatar
Not to sure what to tell you. I have no problems at all. When I was at 4.5" drop I didn't have issues then either. I guess check and make sure everything is installed correctly. Just a thought, did you put the tie rods in upside down? Just guessing...
Old Jul 25, 2011 | 03:04 PM
  #410
azmidget91's Avatar
Everything was installed correct, ill have to try to get under it and see if anything is rubbing that I didn't notice before
Old Aug 26, 2011 | 12:54 PM
  #411
jsvo5695's Avatar
So I received my issue of street trucks yesterday and I actually made the T_S_S ad! It's cool to see my truck in the mag......Even if it is a tiny pic
Thanks T_S_S!!!
Old Aug 26, 2011 | 01:02 PM
  #412
azmidget91's Avatar
pretty cool, just sucks that people will see your truck and figure they will be that low if they buy a "kit" from them, lots of research and trial and error went into it
Old Aug 26, 2011 | 04:18 PM
  #413
fine_style150's Avatar
should scan it and put it in here so we can see!!
congrats jsvo
Old Aug 26, 2011 | 10:54 PM
  #414
c_ulater's Avatar
Congrats
Old Aug 30, 2011 | 08:44 AM
  #415
jsvo5695's Avatar
here it is......
Old Aug 30, 2011 | 09:09 AM
  #416
bankrpt's Avatar
Pic doesn't work
Old Aug 30, 2011 | 09:50 AM
  #417
jsvo5695's Avatar
It works for me.
I will add another link.
Old Aug 30, 2011 | 12:35 PM
  #418
OgRedd's Avatar
Congrats, J! Rig is tight! - Og
Last edited by OgRedd; Aug 30, 2011 at 12:44 PM. Reason: Backwards day. I found J's pic reading this thread back to front.
Old Aug 30, 2011 | 06:25 PM
  #419
azmidget91's Avatar
forgot to mention after i dropped the rear of my truck i can now steer the full range, must have been the caster was so messed up being 2" lower in the front it just didnt like turning that far
Old Aug 30, 2011 | 10:54 PM
  #420
jsvo5695's Avatar
Thanks!
That sounds weird. But as long as it's fixed that is all that matters!
