Let the redo begin!
Old Mar 18, 2011 | 03:22 PM
  #376
bankrpt's Avatar
Any bump steer issues?
Old Mar 18, 2011 | 03:28 PM
  #377
bankrpt's Avatar
Also what cutting, trimming, etc had to be done to the frontend alsobesides the tierods
Old Mar 18, 2011 | 09:29 PM
  #378
jsvo5695's Avatar
When I installed the spindle I had to set the strut to zero. So that actually raised the tie rod.
I trimmed the lower crossmember when I installed my first drop kit. Then the tie rod. And this time it was the plastic inner fender.
I rubbed for the first time today. With my wife, daughter and I in the cab we hit a good sized bump and rubbed a little.
Old Mar 18, 2011 | 11:49 PM
  #379
bankrpt's Avatar
Now when you say inner fender you what part did you cut out? Also when you rubbed what actually rubbed im just wondering instead of doing 5.5 drop doing a 5". Also another thing did notching the lower cross member actually help when I got my last alignment they said the lower control arm was maxed out and I have a slight negative camber nothing bad but id like my front wheels to sit perpendicular to the ground instead of slighting tilting in.
Old Mar 19, 2011 | 12:06 AM
  #380
bankrpt's Avatar
Also where did you buy the spindles from and how much if you front mind me asking also where can I get the instrutions on notching out the lower control arm mount
Old Mar 19, 2011 | 01:41 AM
  #381
jsvo5695's Avatar
I cut some above the tire. And I had to remove a bolt and trim a platic pin that held some wire. And look up the instructions for installing belltech 3" lowering coils on their website. It shows how.
I bought the spindles on amazon.com. I paid $355 shipped.
Old Mar 19, 2011 | 08:15 AM
  #382
bankrpt's Avatar
Ok thanks bud I think I need to trim my lower mounts so it will get my front tires straight up and down
Old Jun 8, 2011 | 01:14 PM
  #383
expedition4x4's Avatar
Do you have any pics of the spindles?
Old Jun 8, 2011 | 05:57 PM
  #384
jsvo5695's Avatar
side by side
Old Jul 6, 2011 | 10:44 PM
  #385
jsvo5695's Avatar
Old Jul 6, 2011 | 10:45 PM
  #386
Center Caps!!!
Looks great, man!
Old Jul 6, 2011 | 10:47 PM
  #387
azmidget91's Avatar
lookin good
Old Jul 6, 2011 | 10:52 PM
  #388
fdimeroller's Avatar
very nice
Old Jul 6, 2011 | 10:53 PM
  #389
jsvo5695's Avatar
Originally Posted by Stealth
Center Caps!!!
Looks great, man!
And ss mirrors.
Old Jul 6, 2011 | 10:55 PM
  #390
She look good!
