Let the redo begin!
Old Oct 30, 2010 | 12:25 AM
  #316
1lohauler's Avatar
right im running 265/50r20 up front and in the rear i have 275/55r20 and lca's is all i have I also have a set of spring spacers as well to lift it a little I have 3.5 lca's and flip with shackles in the rear total 8" drop
Old Dec 28, 2010 | 09:19 PM
  #317
jsvo5695's Avatar
A question for the lowered guys here. I have some bumpsteer in the front and was wondering if I could use a kit similar to the ones that are used on mustangs. It uses a heim joint with a spacer and a bolt. Any ideas?
Old Dec 28, 2010 | 10:40 PM
  #318
steering stabilizer?
Old Dec 29, 2010 | 07:58 AM
  #319
jsvo5695's Avatar
I have thought about a stabilizer. But I think I would like to try and correct my front end geometry first.
Old Dec 29, 2010 | 12:38 PM
  #320
bankrpt's Avatar
Well you best bet is to flip your your tie rods around your tie rods need to be as.level as.possible and no a steering stabilizer wont work. Also make sure you have a really good alignment done I had some bump steer I took it to a different shop for a alignment and bump steer was gone.
Old Dec 29, 2010 | 12:49 PM
  #321
hlbbig69's Avatar
Originally Posted by bankrpt
Black base looks 100% better than ptm base
that is a very nice lookin truckcongrates bro
Old Dec 29, 2010 | 01:05 PM
  #322
bankrpt's Avatar
That's not my truck its my buddies truck down in houston he is selling it if your interested
Old Dec 29, 2010 | 06:37 PM
  #323
jsvo5695's Avatar
On the 04-08(on my truck anyway) the tie rod already mounts thru the bottom of the spindle.
Old Dec 29, 2010 | 08:19 PM
  #324
bankrpt's Avatar
i know im talking about flipping it to the top?
Old Dec 29, 2010 | 08:24 PM
  #325
Wouldn't that make it worse?
Old Dec 29, 2010 | 08:59 PM
  #326
jsvo5695's Avatar
The tie rods are already pointing upward, that is what causes bump steer. So I can't move them higher up. You need the tie rods to be level across or pointing down.
Correct.
Old Dec 29, 2010 | 09:09 PM
  #327
bankrpt's Avatar
i havent looked at the tie rods in forever i know they need to be as level as possible you might need to look into a custom set of upper control arms with a uniball kinda like the camburgs. have you looked at your upper and lower ball joints to make sure they arent bad??
Old Dec 29, 2010 | 09:15 PM
  #328
bankrpt's Avatar
  #329
jsvo5695's Avatar
New lower ball joints. And the uppers were great when I put in the Lca's. I don't have a rattle in the front. Just when I hit a good sized bump on the highway you lose some control of the steering wheel.
Old Dec 29, 2010 | 09:36 PM
  #330
jsvo5695's Avatar
How would uca's help my bumpsteer?
