Let the redo begin!
Old Oct 17, 2010 | 12:36 AM
  #301
jsvo5695's Avatar
How does everyone feel about running air shocks?
Old Oct 17, 2010 | 05:38 AM
  #302
bankrpt's Avatar
I bought a set and used them for a trip I was pulling a big trailer they was fine with me ill sell you mine if your interested
Old Oct 17, 2010 | 09:26 AM
  #303
jsvo5695's Avatar
What model did you buy them for? I went the the parts store and found some for the 88-96 f150 that will work just fine.
Old Oct 17, 2010 | 10:09 AM
  #304
bankrpt's Avatar
What I did was took a shock off measured it fully extended and measured it collapsed and looked in there book and found a shock that was the same measurements
Old Oct 17, 2010 | 11:30 AM
  #305
I have Ground Force 70064 air assist shocks but haven't installed them yet. It's designed to use with their 5" flip kit drop. I was going to use them as an assist for towing or hauling.
On amazon, which is where I got mine, it says they're out of stock, but I'd contact them and see when they will get more since they're so cheap, $55 for the kit (shocks, fittings, and airline tubing).
The image is wrong but the p/n is what I have.
http://www.amazon.com/Ground-Force-7.../dp/B002CVZTBA
Old Oct 17, 2010 | 02:59 PM
  #306
jsvo5695's Avatar
Are they actually "air shocks"?
Old Oct 17, 2010 | 03:20 PM
  #307
They are gas shocks with air assist. The **** is where the airline fittings go which lead to a shrader valve.
Old Oct 17, 2010 | 03:48 PM
  #308
jsvo5695's Avatar
They seem to be nice shocks. But I can't find them anywhere.
Old Oct 17, 2010 | 04:10 PM
  #309
Yeah I got lucky and found the kit on Amazon for $55. Elsewhere they are at least $100 more than that.
Old Oct 20, 2010 | 12:24 AM
  #310
bankrpt's Avatar
Just thought id pass this along http://dallas.craigslist.org/sdf/pts/2011295469.html
Old Oct 20, 2010 | 05:32 AM
  #311
jsvo5695's Avatar
Thanks on the info. But I already have a pair, but they were not that cheap
Old Oct 27, 2010 | 07:31 PM
  #312
1lohauler's Avatar
jsvo do you have any pics of where you cut your front cross member I am running the djm 3.5 drop lca's and I drag on everything and do you have any issues with the inner fender wells or did you cut them out as well?
Old Oct 27, 2010 | 09:17 PM
  #313
jsvo5695's Avatar
I didn't cut the cross member for clearence. I notched it for camber adjustment. No issues with the inner fenders at all.
Old Oct 27, 2010 | 11:03 PM
  #314
1lohauler's Avatar
I dont get it I can hit just a little bump and either my tires hit the inner fender wells or the cross member drags do the single cad trucks sit higher than the extended cad trucks?
Old Oct 28, 2010 | 05:30 AM
  #315
jsvo5695's Avatar
I know the stx's run a smaller diameter tire than the xlt. Maybe that is why my tires don't rub. The only drop components you have for the front are the lca's? I looked at your pics and it does look like it sits really low.
