Let the redo begin!
Old Jun 10, 2010 | 03:12 PM
  #151
fine_style150's Avatar
Originally Posted by jsvo5695
I have the center caps to put on as soon as I find the money tree!! $160+ for lugs????
Thanks everyone for the compliments!
ill ride that boat with you BUT, i have my tips y pipe and magnapack just sitting there dont have much cash for the install, and screw me 05 is local and i was thinkin of buyin the edge off of him...u know the save some spend some kinda deal, its tough!!!
Old Jun 10, 2010 | 03:40 PM
  #152
bankrpt's Avatar
I got a suggestion buy 12 lugs put 3 on each wheel then you can install your caps
Old Jun 10, 2010 | 06:10 PM
  #153
JLstoy's Avatar
What if you do like bankrupt said and put 12 lugnuts that you have to have and then 12 regular chrome lugs. Your cap would go on and they would all look the same
Old Jun 10, 2010 | 06:43 PM
  #154
bankrpt's Avatar
Makes to most since to be might ne able to get by with two per wheel
Old Jun 11, 2010 | 08:59 AM
  #155
jsvo5695's Avatar
Not a bad idea.
Old Jun 11, 2010 | 11:46 AM
  #156
I'd probably try 3 per. You might even be able to convince stealth to try it with his wheels/caps and see what happens
Old Jun 11, 2010 | 12:29 PM
  #157
It will work. That's a pretty good idea. I should have done that and used 3 of my spline lugs to make the 6. Would have been cheaper.
Old Jun 11, 2010 | 12:53 PM
  #158
jsvo5695's Avatar
Yea buddy ol pal........please try!!
Old Jun 11, 2010 | 07:49 PM
  #159
^neat idea!
Old Jun 11, 2010 | 08:02 PM
  #160
It will work, man. I don't need to try. As long as your other lugs fit in the lugnut holes in the cap.
Three Ford HD lugs (triangle pattern) and three other lugs (triangle pattern) then the cap snaps right on.
Old Jun 11, 2010 | 09:07 PM
  #161
bankrpt's Avatar
Thanks all!! You just gotta think outside of the box!
Old Jun 11, 2010 | 09:08 PM
  #162
bankrpt's Avatar
They need to make me a technical article contributer now LOL
Old Jun 24, 2010 | 05:44 AM
  #163
jsvo5695's Avatar
I am getting ready to purchase a set of the djm lca's. Right now I am running 3" spring and drop struts. I am going to run the lca with my drop strut and a stock coil spring to achive the 5" drop. Does anyone run the djm lca's? How do you like them?
Old Jun 24, 2010 | 07:46 AM
  #164
bankrpt's Avatar
I do! been running them since 04 wouldn't think about changing them
Old Jun 24, 2010 | 10:30 AM
  #165
07ScrewF150's Avatar
Where you buying them at? This place has them the cheapest I've seen.
http://www.streetsideauto.com/produc...ampaign=Become
It says 05 4wd f150 on their website but if you cross that part # to djm's website it shows to be for our trucks.
I'm curious to see if it rides any better with that setup, if so be sure to let me know as I'll probably do the same.
