Let the redo begin!
Old Dec 29, 2010 | 09:44 PM
  #331
bankrpt's Avatar
how low is your front dropped now?
  #332
bankrpt's Avatar
http://www.streetsource.com/forum/11...Find-****.html
Old Dec 29, 2010 | 10:03 PM
  #333
jsvo5695's Avatar
5.5
Link did not work.....
Old Dec 29, 2010 | 10:10 PM
  #334
bankrpt's Avatar
thats probably why your getting so much bumpsteer i would contact that shop i posted your upper ball joints are more than likly maxed out
Old Dec 29, 2010 | 10:13 PM
  #335
jsvo5695's Avatar
MMW....I talked to that guy via email. He is very smart and helpful. Just right now With christmas and slow work I can't afford to drop the $300 plus that he wants to make me some heim joints and some spacers to work for my truck.
Old Dec 29, 2010 | 10:15 PM
  #336
bankrpt's Avatar
yeah he is very smart and helpful his upper control arms run about 530 shipped will the mustang bump steer tierods not work
Old Dec 30, 2010 | 09:16 AM
  #337
jsvo5695's Avatar
They might work. But I have not been able to find out any info on the tread pitch of the 99+ mustang.
Old Dec 31, 2010 | 12:56 PM
  #338
jsvo5695's Avatar
any help?
Old Dec 31, 2010 | 01:14 PM
  #339
bankrpt's Avatar
Only help I can think of is go to autozone or your favorite parts supplier ask them for a 04-08 f150 inner tierod and ask them for a 99+ mustang outer tierod and see if they screw in to the inner
Old Feb 5, 2011 | 06:19 PM
  #340
jsvo5695's Avatar
Does anyone have any experience with the belltech drop spindles? I think I might try a set to try and correct some of my bumpsteer problems.
Old Feb 5, 2011 | 07:12 PM
  #341
bankrpt's Avatar
I don't see drop spindles helping bumpsteer that's the problem with our trucks they aren't designed to be dropped that low unless your bagging it and doing custom uca's and raising the upper control arms. You might give status a call and ask them.
Old Feb 5, 2011 | 07:16 PM
  #342
bankrpt's Avatar
http://www.creatingrollingart.com/
Old Feb 5, 2011 | 08:59 PM
  #343
jsvo5695's Avatar
This is why I was thinking they might work.
Per belltech:
By relocating the wheel mounting point a.k.a. spindle pin higher on the spindle casting, our engineers were able to provide a 2-3” lowering without affecting any other suspension or steering geometry, not even the shock absorber!
Belltech Drop Spindles offer a 2 or 3 inch drop depending on the application, while improving handling and retaining factory ride quality. Belltech spindles maintain critical suspension geometry and eliminate excessive ball joint, shock and tire wear common to other methods of lowering. Each spindle is built from OEM grade high strength ductile iron, providing the structural integrity to meet and exceed all factory specifications & requirements.
So by moving the "pin" up it lowers the truck and it does not change the angle of the tie rod. And right now I am using the drop strut which lowers the whole truck, in turn makes the tie rod go up further..........Those are my thoughts anyway..
Old Feb 5, 2011 | 09:49 PM
  #344
bankrpt's Avatar
Well it might work but how are you going to achieve the 5.5" drop
Old Feb 6, 2011 | 08:47 AM
  #345
jsvo5695's Avatar
I figured I would see how far the front goes down with the 3.5" lca's and the 2" spindle's then go from there..
