4x4 wanting to go lowww
Old Sep 10, 2009 | 11:36 AM
abervintageman4's Avatar
unfortunately for you eric, there is only so much you can do on a 4wd as far as a drop goes
Old Sep 10, 2009 | 12:36 PM
bingo, because at the end of the day he has to have room for his CV axles
Old Sep 10, 2009 | 12:58 PM
dirtyd88's Avatar
That's what I told him awhile back. The transfer case can only tuck Unser there so much.
I know this isn't an option for Eric, but theorectically, would you be able to build your own chassis to support a lowered 4wd?
Old Sep 10, 2009 | 01:03 PM
eric you should do some hardcore research and then just figure out a way to drop the bitch really low and do it for a school project
Old Sep 10, 2009 | 01:04 PM
daprib's Avatar
Don't go low with a 4x4, the lower you get the more problems you will have with handling and from what I remember the cv shafts up front will start hainging up if you get to extreme with the t bars.
Old Sep 10, 2009 | 01:52 PM
easiest way would be doing a body drop on the front half of the truck, and just cut and move the frame up
Old Sep 10, 2009 | 03:17 PM
blackedoutV6's Avatar
hell yeah, static dropped trucks with body drops ftmfw! lol
eric never uses his 4wd so what if he takes his driveshaft out and his cv shafts..?
Old Sep 10, 2009 | 04:04 PM
yea that might help, and he'd get better gas mileage
but still there is only so much you can do with torsion bars.
speaking of body drops, i looked into doing it with fiddy before i found out how much of a PITA it will be, with the way the cab is setup. Might just do a custom frame later
Old Sep 10, 2009 | 04:26 PM
lol, stuff some sandbags under the hood? should get an inch or two out of that
yeah from what ive seen it would suck to body drop a 150 compared to like minitrucks, its possible tho..
Old Sep 10, 2009 | 05:02 PM
yah especially on a big cab truck like mine
Old Sep 10, 2009 | 06:46 PM
coobies5's Avatar
damn, this blew up
well i guess some high quality shocks up front and chevy key's and that'll be it then......and guys trust me i wish i had a 2wd, parents are stupid for getting a 4x4......with the 4.6......plain stupid. thanks for the help though! as for the rear, i'd like about 1-2" lower and i'll be happy, so i guess that means hangers? or can i get shocks that will lower me that much?
Old Sep 10, 2009 | 07:56 PM
Originally Posted by coobies5
damn, this blew up
id do hangers in the rear, dont you actually need to use your truck for work though? helper bags eventually?
Old Sep 10, 2009 | 08:55 PM
shocks are not load bearing, so can't make you any lower.
either hangers, longer shackles, or 99-02 SVT leaf springs are your options
Old Sep 10, 2009 | 09:54 PM
8up's Avatar
8up
no way it would be cheaper to bag a 2wd, but drop a 2wd yes
No, my point is that to lower a 4wd as low as I think he wants to go,it would
cost less to bage a 2wd then it would to have a 4wd cut up & what ever it would take to drop it on the ground. Baging a 2wd, I think would be around 5k to 6k.
Much less then cutting up a 4wd and having it be functional.
Yes, just lowering a 2wd 3" to 4" would not be near as that much.
JMO
Old Sep 10, 2009 | 10:14 PM
yeah thats very true
