Alright, now seriously lol
Old May 31, 2009 | 07:21 PM
  #31
bigdog87's Avatar
Odd, Dealer cost audio says those 10w3v3-4 are 300RMS and 600 peak, but on JL Audio, and Sonic electronix they are 500RMS and 1000 Peak..
Old May 31, 2009 | 08:33 PM
  #32
JJDH's Avatar
doesnt matter they are in that range jl has a chart that slides from minimum to optimum ,
Old May 31, 2009 | 09:08 PM
  #33
bigdog87's Avatar
Yeah, Ima go with a the 4 ohm ones and wire em parallel so the amp will be @ 2 ohms.. I'm looking to give them around 500 RMS. So they will really knock!
Old May 31, 2009 | 09:40 PM
  #34
JJDH's Avatar
that is what i have, there u go
Old May 31, 2009 | 09:50 PM
  #35
mSaLL150's Avatar
Oh really? will MURDER them on rap? Do tell
I dont know about "murder" but they will get louder and sound cleaner (given they are put in the same box you are talking about). The IDQs have more cone area and 19mm one way linear vs. the W3s 14mm.
Old May 31, 2009 | 09:54 PM
  #36
bigdog87's Avatar
I'm excited.
What does cone area mean? As far as loudness lol
Old May 31, 2009 | 10:02 PM
  #37
mSaLL150's Avatar
I'm excited.
More cone area and more excursion means the speaker is moving more air. Which means more output.
Old May 31, 2009 | 10:03 PM
  #38
JJDH's Avatar
Dude, if you want the most for your money you will want investment protection. What I mean is you want warranties. Dealercost websites and such dont give you those warranties. The JLs with warranty is gonna cost a lot more. IDQ10v3s would cost about the same as the JLs and will murder them.
That Cadence amplifier comes with a 5 year warranty.
I hope you're joking.
na not joking, the idq10 has almost the same caracteristics as the jl, idqs website sucks, as far as warrenty dealercost honors what they offer, they purchase them and they hold the warranty, until u put them next to each other u wont kno. the w3v3 are impressive, they arent a slouch the idq specs show nothing extra compared to the jl, so what if x max is 4mm more, that just means a softer spider, or taller motor
Old May 31, 2009 | 10:06 PM
  #39
bigdog87's Avatar
Oh true true.
True, I'ma go with JL cause everyone knows JL and local shops could help me with it, if need be! I can't wait to get it.
Old May 31, 2009 | 10:09 PM
  #40
JJDH's Avatar
2/8 ohms Nominal Impedance
Re 3.35/6.7 Ohms DC Resistance
Fs 22.23 Hz Resonant frequency
Qes .490 Electrical “Q”
Qms 1.831 Mechanical “Q”
Qts .387 Total “Q”
Vas 3.10 cuft (88 liters) Equivalent volume
Xmax 19.0 mm One way linear
Sd 399.1 cm2 Cone Area
Splo 85 dB Sensitivity
Pwr 50/500 Watts IDQ
jl
fs-31.49 Hz
Electrical “Q” (Qes): 0.523
Mechanical “Q” (Qms): 7.017
Total Speaker “Q” (Qts): 0.485
Equivalent Compliance (Vas): 1.138 cu. ft. / 32.23 liters
One-Way, Linear Excursion (Xmax)*: 0.550 in. / 14.0 mm
Reference Efficiency (no): 0.185%
Efficiency (1W/1m)**: 84.87 dB SPL
Effective Piston Area (Sd): 53.475 sq. in. / 0.0345 sq. m.
DC Resistance (Re): 3.567 ohm
Nominal Impedance (Znom): 4 ohm
Thermal Power Handling (Pt): 500W
Driver Displacement: 0.049 cu. ft. / 1.39 liters
Net Weight: 12.25 lbs. / 5.56 kg 12.25 lbs. / 5.56 kg 12.25 lbs. / 5.56 kg
* Xmax specifications are derived via one-way voice coil overhang method with no correction factors applied.
Old May 31, 2009 | 10:11 PM
  #41
JJDH's Avatar
the jl is more efficient look at the specs, the idq looks nice, i would call them equal, i considered buying them, after extensive research i stuck with jl
  #42
bigdog87's Avatar
I don't know what all that means, but go JL Audio!
Old May 31, 2009 | 10:13 PM
  #43
bigdog87's Avatar
IMO for around the same price.. Hands down JL just IMO. I'm looking at going with the MTX 1000XD, JL 10w3v3 4 ohm. Install Bay AK01 install kit and fox acoustics box.. I think I'll knock some stuff! Wacha think?
  #44
JJDH's Avatar
sall i posted all specs the jl on paper is a notch above bro
Old May 31, 2009 | 10:23 PM
  #45
bigdog87's Avatar
Is that fox acoustics box ported? or just good? lol
