where to get/ how to fiberglass?
There are some numerous places to pick up what you need. Auto body supply stores, hardware stores, boat repair stores, home improvement stores....the list goes on. My advice (and everybody else who does a lot of fiberglassin) is to stay away from Bondo brand. It works, but it is a PITA to work with. I have been using Poly-Glass (from a local boat supply store) resin and Evercoat body filler. Evercoat Rage Gold is about the best, but be prepared to pay for it.
Thickness depends on what subs you are using. For your average 10's or 12's, 4-6 layers will be plenty. I personally would go to the thicker side of that, maybe into 8 layers. It also depends on how much of the box is actually 'glass. If its a wide, flat spot that you wanna glass, you gotta go a bit thicker...fiberglass gets its strength in curves and odd shapes.
Feel free to ask anything else if you need to.
8 layers for any sub it takes abt 2-3 hours with dry time. And strong as hell.
BE VERY CAREFUL WITH MEKP AND HOW MUCH YOU USE!!!
P.S. watch my thread... You may learn something..
i do 7 layers
i lucked out about 2 years ago i got about 30lbs of some very thick fiberglass from a guy on ftw, still have pleanty to make my console and only need at most 5 layers with this stuff but yeah you can order it online or home depot or walmart or boat stores..........
the site i learned from went down but ill talk you through it on aim some time its really pretty easy just time consuming and very intimidating the first time, my first fiberglass box actually caught on fire when welding near it, i was soooo glad i caught it before it was destroed after the several days of working on it, o and also for a first box i would highly recomend not using mat at all if possible but if you do only use it the first layer or two then use weave over that because mat is very hard to get flat and smooth if you dont know what you are doing
Originally Posted by azmidget91
i do 7 layers
Originally Posted by c0ckac0la
Is that the same as those whale bone folding tools? The kind you find at art supply stores?
Its just like a miniature paint roller in shape. But @ the end its like a hot air curler... Round inside but with spikes all over it and normally Blue in color.
Originally Posted by styxnpicks
don't forget the fleece first, I usually start there with an mdf skeleton. stretchand staple the fleece to the mdf and soak it in resin, then I usuly do two layers on top and three on bottom
Originally Posted by Low_e_Red
I have never used foam... Ive always done MDF skeletons or FBG freehand...
Idk. Never looked there.
My fiance got one to fold paper for our invitations and such. Doesn't sound like the same thing. Is that actually made of bone? Can you get it at Home Depot?
This is what I was thinking:
Really cool site to help you first timer and even regular fiberglassers.Fiberglass ForumsSome really cool tips or even just some great ideas to look at.* Some of these guys just get CRAZY with thier work.* There's a kid on here that built his own wide body kit for his car.* Took him about a year but came out amazing.
