? about wiring and new speakers
Really? I've heard nothing but good things about these speakers.
If they are any decent improvement over stock, I'll probably just stick with em, I got a pretty good deal on them (all 4 for $95). I got them off eBay so Im not sure I could return them even if I wanted, without an RMA
I did some looking around:
Your speakers are 2-ways, the ones I got are 3-ways.
The power ratings are different too...
Yours: 120W Peak, 40W RMS, 35Hz-24kHz range, 92dB sensitivity, 4ohm.
Mine: 220W Peak, 50W RMS, 30Hz-28kHz range, 91dB sensitivity, 4ohm.
WHere are you getting them from? If you bought them off crtuchfield or sounddomain, they should be sending you harness adapters for the speakers. If not you will just have to splice onto the original wires. Or, better yet, run new speaker wires. But with stock power to the speakers, you shoudl be fine with a splice.
Originally Posted by Johngs
I bought the speakers off eBay. They dont come with adapters, so I guess I will just have to splice into the stock wiring. I will just cut the old adapters off and leave enough so that I can splice back into the stock plugs later if I want to.
Thanks.
Thanks.
Well, the speakers got here a day early, and I just had to get them installed. I only had time to get the fronts installed, but it already sounds much better than my stock speakers. Once I get the rears installed Ill play around with the settings on my HU and I think Ill be a happy camper for quite a while
