Sirius Sportster Install/pics
Just installed my Sirius Sportster Replay to my new ALPINE CDA-9853 Head unit. The Sportster is Hard wired to my Alpine via a WIRED FM MODULATOR RELAY from www.circuitcity.com ($20) This relay takes the place of the wireless antenna supplied with the new sportster, connects to your head unit via the antenna port, just unplug your antenna from the back and put it into the relay, then plug the relay into the head unit antenna port, works great, no static. The Sportster is mounted using a Proform mount out of my cousins 97 Expo. it was used to mount his cell phone. (it has several holes for mounting choices).
SPORTSTER REPLAY
CLOSE UP OF MODULATOR TAG FOR ANYONE WHO WANTS PART NUMBER/INFO
BOUGHT AT WWW.CIRCUITCITY.COM
1st, ZAXJAX, my best friend has XM and I prefer Sirius programing over it. The only way I would ever go XM is if Howard switches...basically never.
Thanks for the kind words though.
Hey KCward, I got lucky with mounting my Sportster, since I basically stumbled upon that PROFORM mounting adapter in my cousin's 97 Exp. which had a cell phone mounted to it (not working). So I yarded the whole set up and kept the mounting bracket, it's for a 97 FORD but it works in my 02 Screw. The enclosed suction mount is F'n worthless, or its just my 02 windshield, wouldn't stay anywhere, I really wanted to use it in the lower left corner of the front windshield just above the dash, which would have been out of the way and all wires would've been hidden under the A pillar. You should be able to find some different mounting solutions on EBAY - etc.
Good luck.
Good luck.
Hey KCWARD, FOUND A MOUNT FOR YOU. BELOW
http://www.gbxdirect.com/store/swive...04&yearto=2005
oK, msugeotech, ABSOLUTELY YOU CAN USE THE WIRED FM MODULATOR RELAY with your 6 disc changer, the relay plugs into your deck via the fm antenna port, all you have to do is unplug your antenna from the back of your head unit (stock or after market - doesn't matter), plug it in to the modulator, then plug the FM mod. into the back of your deck in the FM antenna port. done, ready to go.
