Getting More Power - 94' 5.8L
if it has been converted to MAF you already have gained some power. if you want serious power you're gonna need to build the motor. bore it out, cams, bla bla bla. I was happy with the power we got out of our 91 with adding longtube headers, and deleting the emissions system. (wouldn't recommend an emissions delete.) First take a pic of the engine bay and post it to show us if it has MAF or Speed Density.
Need to know if it has a MAF conversion or if it's Speed Density (SD).
Cap, rotor, plugs, plug wires, ignition coil, air filter and fuel filter.
Bump timing to 14*, 91 octane or better fuel required.
Headers and dual exhaust.
130 amp alternator upgrade, new hi-amp charging cable and electric fan.
A Punisher street valve body (VB).
MAF is first, it will handle some basic power adders well. Intake, Heads, cam, headers, and exhaust.
Then you need a tuner to get more. Moates Quarterhorse or Tweecer
Definitely a tuner to get way more, like to stroke it or to add boost. Don;t forget the fuel pump and larger injectors
Then the rear end and tranny better be up to the task.
Sure there are and two forums to back them up!
Tweecer:
product - http://www.tweecer.com/index.htm
Forum - http://autos.groups.yahoo.com/group/tweecer/messages
Moates Quarterhorse:
Product - http://www.moates.net/quarterhorse-for-fords.html
Forum - http://eectuning.org/forums/
Plenty of help, you can get a driveway tune based on your build, and go from there....................................become a tuner!
Tweecer:
Sorry guys, I meant to say Speed Density - the OEM set up. A couple years back I went looking around and found that there was virtually nothing that could be done to add significant power as long as it retained the Speed Density air flow system. I was also unable to find any type of conversion system. I thought I would check to see if any progress has been made in recent years with this set up. I installed a set of shorty headers, dual exhaust, K&N cold air intake, throttle spacer and for a time even ran a Hypertech chip but if all of these add on did anything it was negligible. I took the chip out a couple years back to go back to using regular gas. I would really like to get this motor up to 350-400hp - without resorting to a blower..
