Can you clean this inside of a gas tank
This is a product that have seen on the PowerBlock series on Spike TV. I have seen this product used, and recomended many times over the yeas, and it is quit in-expensive compared to the cost of a new fuel tank.
KREEM METAL GAS TANK CLEANING & COATING KIT,TANK REPAIR
"This is a brand new Kreem gas tank cleaning & coating kit. It comes with 3 chemicals to help repair your old metal rusty tank. One bottle is a cleaner which loosens up and frees rust inside the tank. The second bottle is a rinse, it removes all oils and chemicals. The third bottle is the cream which will coat the inside of the tank so it will never rust again. This is an inexpensive way to repair old internally rusty tanks & it works great when done right. This kit includes all 3 chemicals & instructions. Free shipping is in the US"
Ebay Item number: 400208735770
WOW I just furthered my research and found you can actually replace your fuel tank cheaper then you can clean your tank with the above mentioned cleaning and treatment of your existing tank!!
73 - 78 Ford F 150 250 350 100 19 Gallon Gas Fuel Tank
Description / Notes:PZNARBF670107
Warranty: 18 Months
Warranty Terms and Conditions
"Prozone Fuel Tank -- PROZONE FUEL TANK, GALVANIZED STEEL, SILVER, 19 GALLONS/72 LITERS -- 34.75 in. L x 27 in. W; A high quality, direct fit OE replacement fuel tank; Features all-zinc external layer, combined zinc and iron mid-section, and pure steel core; Its multi-layered construction is designed to withstand corrosion-inducing circumstances such as saltwater or moisture"
Material : Galvanized steel
Capacity : 19 gallons / 72 liters
Dimensions : 34.75 x 27 in.
Product fit : OE replacement
Color/finish : Silver
Condition : New
Brand New in the Box - Fit and Quality Guaranteed!
$64.64
FREE SHIPPING FREE SHIPPING WITH FREE SHIPPING FREE SHIPPING
EBAY ITEM NUMBER# 190524665149
Warranty: 18 Months
Condition : New
$64.64
on
I wouldn't use that Kreeme treatment first.
I'd empty the tank, pour in a few cans of Berryman's B-12 with an equal quantity of fresh gas, shake it, & seal up the tank for a few hours. Then dump that mess into a sealed container for recycling, & see how much progress you've made. If it looks good, repeat it until it's clean. If not, start shopping for a tank.
I didn't even bother with these because they're so common:
I just burned the old tanks to clean them, and then trashed them.
Thanks guys. This tank is so bad I'm going to buy new. Thanks for the link to discount body parts, they are cheaper than anybody else.
This old tank is so rusted I poured in muriatic acid and scrubbed the inside with a steel brush and it didn't knock out 20% of it. It'll never come clean.
