oem rf269 electric fan
Hi.
RF-269 - Also known as Ford/Motorcraft part # BL3Z-8C607-A
It's a 2010+ OEM dual fan assembly.
One fan is 14.5", the other 15"
Specs ( courtesy DCC )
All specifications @ 14V, measured current, calculated cfm
Small fan
Diameter 14.5"
Hub diameter 5.5"
Current (no load) 24.83A
Current under load 26.24A
Starting current 69.64A
cfm (no load) 2797 cfm
Large fan
Diameter 15"
Hub diameter 5.75"
Current (no load) 27.64A
Current under load 36.35A
cfm (no load) 2964 cfm
Total
Current (no load ) 52.47
Current under load 62.59A
Starting current 139.3A
cfm (no load) 5761 cfm
.. You'd better have a very high quality and stout controller to run these things reliably.
Yer welcome.
MGD
Those specs are from him - as long as he knows those are fans you are going to run with that controller and he's approved the compatibility, you should be fine.
Just curious, did you consider one of his variable speed models?
Good luck!
MGD
