questions/build thread for my truck
Old Feb 4, 2010 | 02:11 AM
  #46
Klitch's Avatar
shearing forces are more amazing than you want to realize... dont count on them staying together without proper torque.
Old Mar 2, 2010 | 04:59 AM
  #47
Klitch's Avatar
*****, I need new rubber, my brother dropped off the 37's my dad use to run... whered you get those front adapters?
funny i'm considering doing what i jabbed at you about doing
Old Mar 2, 2010 | 10:56 AM
  #48
willys5555's Avatar
haha its all good. but here is the link:
http://www.airbagit.com/Wheel-Adapters-s/1572.htm
are you going to run 8 lugs or something?
Old Mar 2, 2010 | 12:02 PM
  #49
Klitch's Avatar
thinking about nabbing a 10.5, slammin it in the rear, and adapting the front until i decide what to do. or I may just run the rubber off his KM2 37's using the axles i have now with the 4.88s.
my brother chucked fresh 37's off the family diesel lol
Old Mar 2, 2010 | 01:22 PM
  #50
willys5555's Avatar
haha nice nice...well i cant wait to get those stupid adapters off...definetly just a temporary fix. lol oh and just an FYI, i had to clearance the calipers to get them to fit in the front.
Old Mar 2, 2010 | 04:45 PM
  #51
Klitch's Avatar
boo. that sounds not entertaining lol
Old Mar 2, 2010 | 05:53 PM
  #52
willys5555's Avatar
haha its not too bad. just a little bit. but you have to take the calipers off inorder to grind on them. other than that its fairly easy. haha
Old May 11, 2010 | 05:46 PM
  #53
willys5555's Avatar
well i got a couple questions for you guys. So i have heard that i need to put atleast 10" of lift on the front suspension in order to clear that front crossmember with the solid axle. so first off, is this true?
my next question is what should i do? lol i am stuck on the fence whether i want to go that high or not. first off, i am afraid it will make my tires look too small...what do yall think it would look like with 13" of lift and 38" tires? my other concern is the actual height of the truck. the higher it goes, the less stable it is with a higher center of gravity.
my other option would be to cut out that cross member and weld in a new one...how reasonable is that to do? if i do that, then i will be able to keep the truck at the same height. BUT i am afraid i will rub the fenders because even right now i am rubbing the fenders. I would really like to get it set up to the point where i dont rub at all.
so yea just let me know what yall think...i like bigger trucks but i just really dont want to increase my risk of a roll over. so please put in your input on my delima. haha
Old May 11, 2010 | 08:45 PM
  #54
Klitch's Avatar
Farmboy Fab recommends 6.5" of total lift BARE minimum.
This is the route im going.
Old May 11, 2010 | 09:02 PM
  #55
willys5555's Avatar
so if i go with 8", i should be good then right? I wont have any interference with that front crossmember?
Old May 11, 2010 | 11:44 PM
  #56
Klitch's Avatar
8" was the rumored # to clear without modifications
Even if so, a little welder and a couple notches, you can make clearance :P
Old May 12, 2010 | 12:14 AM
  #57
willys5555's Avatar
awesome. thats what im gonna shoot for then.
Old May 12, 2010 | 11:03 AM
  #58
4.2trimble's Avatar
remember if you cut that crossmember out you need to weld a new one in first then cut that one out.
but you should be fine with 8" of lift
Old May 14, 2010 | 01:18 AM
  #59
willys5555's Avatar
haha yeah i wouldnt want that frame shifting at all while changing the crossmembers.
but i got another new toy for the truck...nothing to do with the sas but it was a late birthday gift
i think i know what im doing this weekend now
Old May 14, 2010 | 04:20 AM
  #60
alex7191's Avatar
hell yeah!
