Steering wheel too low
Old Feb 2, 2009 | 10:47 PM
TB150's Avatar
I just got a 2005 F150 and compromised on one little detail. the top of the steering wheel masks the top part of the speedometer. Can't see if I'm doing 50 or 70 but I got a bad hunch that the highway patrol might let me know.
. Any way to raise the steering wheel? The origional paperwork on it said it had tilt steering but there's no lever or any hole where one might have been. The column looks solid. I don't really need the tilt thing, but raising it would sure help.
TB
Old Feb 3, 2009 | 05:25 AM
memLT-1's Avatar
There is a lever on the lower left underside of the coloum.
Old Feb 3, 2009 | 09:05 AM
2008_XL's Avatar
They're all adjustable. Under the wheel there's a piece that pulls down and allows you to adjust the wheel.
Old Feb 3, 2009 | 09:36 PM
TB150's Avatar
I looked all over the place and couldn't find anything resembling a lever under the steering wheel area. Maybe it was broken off? I'll look again as soon as it stops raining (snowing?). Sure hope you guys are right about all F150's having tilt steering.
Old Feb 3, 2009 | 09:42 PM
GreenBuck50's Avatar
My XL has a tilt steering wheel... so I assume they all have it... the lever is a tad different then other cars/trucks that I have been used to, but it is there.
Old Feb 3, 2009 | 10:06 PM
MmmBuckles's Avatar
my XL doesnt have a tilt steering wheel
Old Feb 4, 2009 | 10:22 AM
2008_XL's Avatar
That's only because your truck is older. All 2004+ F150s have tilt wheel no matter what model they are. If this guy doesn't have one on an '05 than it must have broken off.
Old Feb 4, 2009 | 05:09 PM
TB150's Avatar
Yep, it broke off. Pulled into a Ford dealership today and had it looked. Seems that it makes a sharp right turn into the steering column. Order a new one because I really, really want to see how much over the speed limit I'm doing. For a relatively small fortune, it'll be fixed in a day or two which is probably a whole lot cheaper than a ticket.
Thanks for the help and info you guys provided. I suspect I'll be back shortly with another question or two.
TB150
Old Feb 4, 2009 | 05:24 PM
An even better fix is to get the Gryphon with it's digital gauges, one of which is a speedometer. I had the same problem until I got mine.
Old Feb 5, 2009 | 08:46 PM
Fifty150's Avatar
Is the dealership fixing this for free under warranty?
Old Feb 24, 2009 | 03:26 AM
lObOdiablO's Avatar
driving a 2008 here
my tilt steering wheel got broken
cant even move it up or down
so dealer replaced it under warranty
