System
Old Nov 19, 2010 | 09:47 AM
  #31
DirtySCREW's Avatar
Originally Posted by Ford12508
Why are you running it in 4Ohm? that amp you posted is only 125W when its 2 channels and 4 ohms.
True...BUT bridged it is 500w X 1 at 4 ohms!!!----DirtySCREW
Old Nov 19, 2010 | 10:52 AM
  #32
Gtullous's Avatar
yep.......same amp i have with 2 10's bridged......sounds great...
Old Nov 19, 2010 | 01:06 PM
  #33
joh408's Avatar
If you want a class D which is smaller and more efficient thus less heat, I've seen the Sundown SAZ-1500d go for the same price as the amp you previously posted. This amp will allow you to wire your 4 ohm DVC down to 1 ohm, which means they will see 1000w from the amp. You will have to keep your gains down in order not to fry your subs but more power is better than less. Sundown's have a good rep in the car audio world and if you want to upgrade your subs in the future, you wouldn't have to upgrade your amp in most cases.
Keep in mind I have learned most of this from reading forums, sorry if I have said something incorrect
Old Nov 19, 2010 | 04:11 PM
  #34
jpf150's Avatar
Thanks for the info man. I appreciate it. I know nothing about wiring up these amps and how much wattage I need...etc. I am trying to learn as much as possible. was that a new price or used on that amp?
Old Nov 19, 2010 | 04:17 PM
  #35
joh408's Avatar
New price. I don't remember the actual site right now but I'll look for you. You can use http://www.rockfordfosgate.com/rftec...er_wizard.asp# to help you with wiring. I'm asked the same questions you are when I was first looking into changing my system, now the great guys on here and diyma gave me some great answers
Edit: Found it haha, that was fast: http://www.woofersetc.com/p9255/SAZ1...-Amplifier.htm
Old Nov 19, 2010 | 04:22 PM
  #36
jpf150's Avatar
sweet thanks once again. Ill definitely be putting some reading time in so I can get these for christmas and make a box and be hooked up before Jan. is over.
Old Nov 19, 2010 | 05:48 PM
  #37
DirtySCREW's Avatar
if this is the case, why isn't anyone answering my thread??
https://www.f150online.com/forums/ot...ct-system.html
--DirtySCREW
Old Nov 26, 2010 | 01:59 PM
  #38
jpf150's Avatar
this is what im getting....
12 inch p3 shallow rockford (400 rms)
r500 amp (320 rms)
custom box(me and dad will make it when I get the subs)
might do a seat lift for them
then with money I get for christmas I might buy
P1683 rockford 3 way speakers (65 rms each)
P500-4 amp (60 rms at 4 channels)
what do yall think?
Old Nov 26, 2010 | 05:22 PM
  #39
DirtySCREW's Avatar
Yea, sounds good. I'm undecided on subs because of mounting depth. I figure I'd make my box (or try to) and go from there. I'd like to fit regular subs, but I dunno if I can. I've seen some regular subs that are close to the shallow mount ones. I've heard the Pioneer Shallow subs sound better than the RF. Again, I don't know and thought I'd just pass along. I will say I have always been impressed with the Pioneer shallows! I'd personally like to fit some JLs under the seat...but again....don't know about the mounting depth. I figure I'd built it the best and biggest I can and that would give me room for more options. I'm probably gonna go with the Alpine MRP-M500 for my sub amp.---DirtySCREW
Old Nov 27, 2010 | 12:08 AM
  #40
jpf150's Avatar
I will most likely add another 12 later on, but right now Im looking to make a nice thump on a budget, not win any competitions. and with limited time Im just gonna go with a shallow and only 1 so I KNOW it will fit no problem.
