Frustrated With Troyer's E-Fans And Their Services
Old Nov 20, 2012 | 09:43 PM
  #181
jbravo316's Avatar
Originally Posted by OGTerror
Thankz for your detailed info MGDfan I just forwarded it to the shop where my truck sits since this morning. While we wait for a month or 2 before troyer finally decide to send the controllers, the shop is wiring the fan to the ignition; cause 2 thing has been happening since I wired the fans to a kill switch: 1, I either forget to turn the fans on and I overheat or I forget to turn them off so guess what my battery drains out. This has happened twice in 3 weeks and overheated countless time cause I keep forgetting to turn on the fans.
At first I thought troyer was a pain in the neck but now I'm starting to have a much lower opinion of him.
Aaawwwwwwwwww !!!!!!!!!!!!!!!!!
Guess I'm not the only one who thinks this.
Old Nov 21, 2012 | 01:35 AM
  #182
thundertrucker's Avatar
Question Mine work 6 years and running but need a tweak...any help?
I got my fans done in 2006. Last month the relays melted after 6 years. (The burnt wire smell lasted a week in the truck) Troyer sent me 2 new modern controllers and it's all good again. I do have an issue though. The 2nd fan is wired to the A/C clutch and kicks off/on when I run the heater. I live in Michigan and don't need the 2nd fan running with the heater/defroster. It takes a bit to come to temp just for the primary and the backup running with the defroster makes it longer. How can I rewire this? A switch in-line maybe or can I just disconnect the green wire to the clutch and have the fan run on temp only?
Any help? Our 1st snow is set for Black Friday. Joy!
Old Nov 21, 2012 | 09:51 AM
  #183
grizzstang's Avatar
thundertrucker, I was in the same boat as you. I ended up adding a plug to that wire so in the winter I just unplug the A/C connection. Problem solved. I didn't even bother to plug it back in last summer and the A/C was cold enough for me.
Old Nov 21, 2012 | 11:50 AM
  #184
sam1947's Avatar
This is another alternative for a controller http://www.madenterprise.com/fan%20control.htm This controller senses the temp of the condenser to trigger the fan, not the AC clutch wiring. I have this controller on mime for the past 1 1/2 years and has worked flawlessly for me
Old Jan 31, 2013 | 01:27 PM
  #185
f150exp's Avatar
Thumbs down troyer pulleys
I had the same problem with Troyer pulleys for 2009 f150 off idle power was gone with irratic idle. no check engine light but noticeable power loss. They wouldn't refund, so I also have a set for sale $100 obo I would never buy from them again, once I relized the also sold Dynatech I new I was in for trouble. I have spent thousands in performance items over the years, and these 2 companies have no business selling anything.
