New CB radio antenna
Originally Posted by Pheonixx
if for any reason you EVER pushed the button on your CB without an antenna while in CB mode you fried it.
Ch 9 = Emergency (If I had an emergency I wouldn't use the CB)
Ch 19 = Main trucker channel. Cops monitor this often. Never actually heard a bear come alive on it tho.
Ch. 1-8 & 10= Common private party channels (me & my friends use 4)
Yea, mine does that as well...well, the noise after turning on. I think it's electrical noise, though I'm not sure. Is yours hardwired, or cig mounted. I've heard hardwiring helps eliminate some of the noise(I need to do that sometime.) Sometimes, when sitting with the car off in a parking lot, you can pick up other people's engines, as well as when they lock/unlock their cars. Kinnda cool.
Having the NB/ANL(forgot what it means) turned on helps mine alot, but I don't think that's found on some of the cheaper CB units.
all that i have to say is that a 2 ft antenna wont get you much if you want to hear some chit chat i would recommend a 10 ft whip or 5 ft fire sticks i have had both and pefer the firestick on the old body style my buddies and i have played around with all antennas and found that whips do offer better range and not as much static but it gets old having to bend the whip over into the back of the truck every time you want to go through a drive thru or park in the garage
it also depends on what type of cb you have and whoever said that if you press the button without an antenna ur a moron you must have read your directions nuthing really happens exctpt you dont hear any one and they cant hear you
Originally Posted by sully853
is there a reason why when my truck is off i get great reception and can hear everyone clearley but when i turn my truck on it gets much more fuzzy.
How do i fix this?
How do i fix this?
