Drive shaft loop
Old Aug 28, 2002 | 11:43 AM
struckby01's Avatar
Drive shaft loop
Hey Guys! Which vender drive shaft loop is easiest to install.From the websites and pictures looks like JLP but i could be wrong.Which one most of you guys are using. Thanx JACK 2001 RED L
Old Aug 28, 2002 | 11:54 AM
Flying Mofo's Avatar
Banned
Johnny Lightning's. They are all easy, but hell with his, you dont even need to drill holes into the frame! Lines up with holes already there.
Old Aug 28, 2002 | 12:01 PM
JBLsilver01's Avatar
I second the JLP loop. Took about 5 minutes to install and was the best price out of all of them.
Old Aug 28, 2002 | 12:06 PM
LightningTuner's Avatar
Our PSP loop is the same basic design as the JLP:
http://powersurgeperformance.net/Sho...pexd.asp?id=55
A few people here have nice pics of it installed.
Old Aug 28, 2002 | 12:19 PM
MiamiWhiteSVT-L's Avatar
Forgive my stupidity here.................but what advantages does a drive shaft loop give our trucks? I'm not too familiar with their use...sorry, I now seem that much more ignorant!
JC
Yeah I would recommend the PSP one if you have custom exhaust, as it is a bit lower on the muffler side. Luckily my JLP is just about an inch away from my Magnaflow muffler.
Miami : The purpose they serve mainly has to do with running slicks at the track. If that driveshaft breaks, it can do some serious damage unless it has a loop to catch it.
Old Aug 28, 2002 | 01:28 PM
Johnny AC's Avatar
Exclamation Re: Drive shaft loop
You're right Jack, Johnny's loop is the easiest to install, but do you want the easiest to install or do you want a safe and effective loop, (Metco). I had JLP's loop on my truck, but I gave it away after seeing how well the Metco loop is designed, ease of installation doesn't even hold a candle to safety, just my 2 cents, John H.
Old Aug 28, 2002 | 01:30 PM
Coldie's Avatar
Advantage
First off: a loop is required if you are running slicks or under 13 seconds at a drag strip.
Second: The reason it's required is if you break your driveshaft without a loop, you car will turn into a huge pogo stick and make a big mess of you and the street...
Coldie
Old Aug 28, 2002 | 01:56 PM
struckby01's Avatar
Where can i find Metco products , how much, and what is invalved in intallation. JACK 2001 RED L
Old Aug 28, 2002 | 02:08 PM
Banned
Re: Re: Drive shaft loop
Not to start a flame fest, but please list the discrepancies in JLP's Driveshaft loop that make metco's more effective and safer? I can hardly fathom JLP or PSP making a loop that was unsafe...
Old Aug 28, 2002 | 02:17 PM
blown318's Avatar
JC
well one gas tank, driveshaft, and new bassani exhaust system later....... I decided to get a loop... Driveshaft decides to go agian.... only need a new shaft(hehehe i said shaft) trust me THERE WELLL WORTH IT!!!!!!
Old Aug 28, 2002 | 02:20 PM
blown318's Avatar
my JL loop worked fine...
Old Aug 28, 2002 | 02:54 PM
DHFerguson's Avatar
When I was in college a guy (a mid 60's 'greaser') was racing up and down State Street in front of the Fieldhouse showing off on a warm night. His front u-joint broke just as he passed our balcony and the engine overreved and blew apart. He continued for about 100 yards before the front of his driveshaft hit a crack or pothole and lifted the rear end WAY in the air. He didn't go over, but it sure made a mess under his car! I still smile when when I think of the verbal bashing he took from the 'pin-heads'.
Old Aug 28, 2002 | 03:53 PM
mecca's Avatar
Hahaha. Now thats gotta suck!
-Mike
Old Aug 28, 2002 | 04:03 PM
Johnny AC's Avatar
Exclamation Re: Re: Re: Drive shaft loop
Never said JLP's or PSP's loops were "unsafe", I stated that Metco's was safer. I've had them both on my truck, have you? John H.
