Drive shaft loop
I got news for you John, looking at those pictures, the Metco loop is farther back than our PSP (or JL) loop is. And besides, NHRA rules say the loop can't be more than 6 inches back from the front U-joint, so I still don't see your point on why the Metco one is better than any other.
I think any of the loops will work just fine. I hope I never need it, but it is nice to know it will work.
Durring my time at the track, I have seen guys drop driveshafts. All 3 of them did the job. So use the one you want.
Ruslow sells a drive shaft loop that is probably 2 times thicker steel than any of the above listed drive shaft loops. It is a one piece design also. I have used the JL loop and currently use the metco loop. I like the metco because it doesn't get in the way of the mufflers like the JL loop did(I used some washers to lower the loop and it worked fine.)
picture of Ruslow DS Loop stolen from someone else
Re: Jack,
Originally posted by Lightning Bob
Buy the Metco.
Your truck is already drilled for it.
Buy the Metco.
edit: nevermind, I'm guessing he has a used used truck which had a metco dsloop in it?
Re: Metco loop
Originally posted by Johnny AC
Hey Jack, just give Jim @ JDM a call, 732-780-0770 and he can give you all the details on the benefits of a Metco loop versus the other loops that are available, he probably has them in stock, hope this helped, John H.
I think you deserve the award, im sure someone will post it soon
Originally posted by Coldie
They can't (legally) void your warranty for a drive shaft loop.
The metco does go through the floorboard, but I wouldn't worry about it. It's pretty heavy duty where it goes through...
Coldie
Coldie
Originally posted by wydopnthrtl
Is there only one need towards the front? (for track leagality)
Thanks, WOT
Thanks, WOT
Thanks, WOT
Thanks, WOT
this may be overkill (or not) but how about also having a loop for the REAR since this is where most our driveshafts break. (knock knock)
The undercarriage and gas tank take a tremendous amount of abuse when these let go.
Traction devices obviously address the axle wrap issue BUT...
JMHO.
Back to you regularly scheduled bashing, or something..
JMHO.
