Rigid Dually Diffused Backup Lights
Old Jun 24, 2013 | 03:19 PM
zxd9's Avatar
OK, got my lights last Friday and installed them on my '13 FX2. I didn't want to do any drilling so I mounted them on existing screws on the bumper. I also felt that mounting them under and back a little bit would limit the available light output.
My initial installation was going to use the 7-pin trailer connection. I bought the trailer side of the connector and wired it up. Nothing. Check the voltage and it was about 8-10v (old analog meter, hard to read). Check at battery, reads 10+. Run wires directly off battery, lights work. OK, so it's not the lights. I return the 7-pin connector and get a different one thinking there is something wrong with it. Same issue, except with only one light plugged in it will blink now. Cool, a strobe light!
I decided to skip the trailer connection and just tap into the reverse wire on the truck side of the connector. Bingo! Bright light!
Has anyone ever seen voltage drop across the trailer connector? Doesn't seem right.
Very happy with light output for use as a backup aid. Will work on angling them a bit to see if that helps or not.
I know, truck is dirty. Just got back from the shooting range which has a long gravel driveway.
Standing by passenger side rear bumper
Passenger side about 6' away
From Drivers side at rear of truck. NIGHT TIME!
From Drivers side at rear of truck. DAY TIME!
From the rear seat looking out rear window
Backup Camera View
Looking at back of truck from about 15ft away.
Old Jun 25, 2013 | 02:57 PM
Raptor05121's Avatar
Good thing you hid that license plate. I was hoping to scrounge some personal info
Old Jun 25, 2013 | 04:19 PM
zxd9's Avatar
Hey, you broadcast to the masses what you want and I'll hide what I want.
Are you indicative of the type of users on this forum? If so, I can see why this place is a little slower than other related sites.
Old Jun 25, 2013 | 04:32 PM
Barrett's Avatar
Think he was just joking, chief.
Looks real sharp though. Mind if I ask where you got the lights from?
Old Jun 25, 2013 | 04:53 PM
zxd9's Avatar
Thanks. I bought them at 4wheelparts.com
He may have been joking. That's the problem with the internet. Ya can't always interpret comments like that properly.
Old Jul 11, 2013 | 02:14 PM
Pockets's Avatar
Looks great ..... I'm looking to replace my now two dead PIAA 1500 reverse lights I have mounted under my bumper
Do you like the diffused lenses or do you think the flood would have been better? Are you happy with the distance of the light could you use them as a work light?
Old Jul 11, 2013 | 08:23 PM
zxd9's Avatar
Well I can't compare to floods because I haven't seen those in person.
They provide plenty of light to work with as long as you are within 15ft or so, then it really starts to taper off.
What I like is that with them mounted at the edge of the bumper, you also get a lot of vertical light too.
Old Jul 11, 2013 | 09:13 PM
jdruzik's Avatar
Outstanding... Very sharp... NICE...
Old Jul 11, 2013 | 10:03 PM
nice! but you should remove that awful dealer tag
Old Jul 12, 2013 | 12:41 AM
The lights look good!
I've been thinking about grabbing some reverse lights like this. I can't see crap at night as it is, and I'm planning on getting 5% tint. Thanks for the pics, might have to check these out!
Old Jul 12, 2013 | 08:45 AM
zxd9's Avatar
Thanks for the comments guys. Yeah, the dealer sticker has to go.
Old Jul 12, 2013 | 09:39 AM
Nicely done!!!
Old Jul 12, 2013 | 11:35 AM
Pockets's Avatar
Sweet thanks for the response
I think I might go with the Flood because I would like a little farther throw as I'm backing up
Sucks that you have to mount them upside down ... wonder if you can take the faceplate off and mount them that way.
Old Jul 21, 2013 | 09:05 AM
zxd9's Avatar
Pics of my switch from http://otrattw.com.
I used an ON/OFF/ON switch so I could set them for reverse only or manually turn them on as needed.
Old Oct 3, 2013 | 12:11 PM
cbbennin's Avatar
I have a SPST switch wired to do the same thing - I can either manually turn the lights on anytime I want, or when I go into reverse the lights come on automatically...either way works great and am glad I have the option to manually turn them on!
