HID's went poof
The only kit to get is a Phillips HID kit, anything else is garbage and you're better of with "whiter" halogens. IMO. As someone who does a bulk of their driving at night, HID's are a near requirement.
on
Had to go look, Sylvania some time back had the Xeonarc HID kit that replaced the headlamp housing for 00-03 MY trucks.
This one was quite funny, found a site ( hiding under a Phillips name similar domain name ) , selected the menu option on the left for Glare Resistant HID Kit
This is what came up on the page :
There are no products in this category.
HID bulbs? Connect to a known good ballast - can't really tell using the Mark 1 Eyeball test, unless the capsule is obviously compromised.
I've had horrible experiences with the garbage chinese s**t in the past, but my wife's truck is driving 4 years on the "XENTEC bi-xenon" kit (might have helped me a while ago to be smart and use a relay and harness like I did hers). More than likely it's a ballast that died. Your best bet is to look around and ask about HID sets. Personally, I got my current set from ddmtuning.com and I've had no problems with it. Just make sure you get the harness for it because like MGDfan said, PnP = Plug 'n Pray.
