F150Online's Retrofit Members
Old Nov 30, 2014 | 08:05 PM
  #151
03f15012's Avatar
Finally got a set, quite happy. They are just Morimoto MH-1's with 4300k XB bulbs and 6000k smd LED halo's in black Harley Davidson headlights. Shrouds are mini gatling painted flat black. There are better projectors out there, but I just got a stupid good deal on the whole kit. $150 shipped to me for everything!
Old Nov 30, 2014 | 08:44 PM
  #152
Looking good....
Old Dec 2, 2014 | 07:40 AM
  #153
sledman62's Avatar
Here's my set-up, FX-R 3.0 3" Apollo 2.0 flat top shrounds, amber halos, all blacked out.
Not bad for the first one's I've done. Next set will be better.
Old Dec 2, 2014 | 10:11 AM
  #154
Raptor05121's Avatar
Thanks for posting. Unfortunately, we ran out of room in the first two posts so I cannot add any more retrofits.
Old Dec 2, 2014 | 10:26 AM
  #155
MGDfan's Avatar
Oye.
So - start a "Part Deux" Thread. Been done before ...
BSB
Old Dec 2, 2014 | 11:21 AM
  #156
03f15012's Avatar
Originally Posted by MGDfan
Oye.
BSB
Can we call it the "Second banana retrofit members"? Seems fitting enough.
Old Dec 2, 2014 | 11:41 AM
  #157
MGDfan's Avatar
Outstanding! We can then add 'nanners as necessary...
Works fer me, buddy!
MGD
Old Dec 2, 2014 | 01:37 PM
  #158
Use yer #5 and #8 posts and add names there....simple fix
Old Dec 2, 2014 | 01:39 PM
  #159
03f15012's Avatar
MGD
Damnit, sumwun get me a PBJ sammich. 'Cause it's time.
Old Jan 23, 2015 | 01:25 PM
  #160
navyrpdavis's Avatar
I have a question for you retrofitters. I am retrofitting a set of 2010 f-150 spyder headlights with Morimoto Mini H1 6.0 projectors. The lights are for a buddys truck but he is not skilled in this. My question to you is that when he has his low beams on, if he turns on his high beams, will it turn off the low? the projector is a bi-xenon which im sure you all know. If so, is there a way to keep that from happening?
Old Jan 23, 2015 | 02:13 PM
  #161
And
http://www.hidplanet.com/forums/show...arket-housings
Old Jan 23, 2015 | 02:18 PM
  #162
thelariat02's Avatar
Look up sir Speedstang he has done this exact thing to his truck with spyder lights and should be able to help you
Old Jan 24, 2015 | 01:46 AM
  #163
speedstang's Avatar
I sent back harness that came with the quick retrofit for the spyder lights. I am using just the harness for HIDs as if the high halogen beam on the spyders isn't there. Hi n low R hid. Hid stays on the whole time n shield flips down for hi beam.
I didnt want the crappy hi beam halogen hooked up. If I could go back i wouldve retrofitted my factor lights instead of buying the chinese crap. If u got it from TRS tell them u want harness for ur truck for hid's only.
Old Jan 24, 2015 | 01:52 AM
  #164
speedstang's Avatar
If your wanting only hid low beam n then the halogen hi beam, not sure if that can be done. For starters, don't hook up the solenoid for the hi beam shield actuator. N you would have to ask TRS bout the rest. Prob not good for the hids if they turned off every time u flicked to hi beams. Not sure if that's what ur askn. Shoot me a pm if u have any questions.
Old Jan 24, 2015 | 08:15 AM
  #165
MGDfan's Avatar
Not sure of exactly what he meant either (and I agree that rapid HID switching is very bad juju), but regardless, any switching arrangement can be easily done with a mildy custom harness, if something can't be cobbled together from available standard components in the TRS harness section.
FWIW - HIDplanet has a harness building forum.
