I replaced my blend door and heater core. Happy ending!
Old Sep 4, 2007 | 08:55 PM
  #181
tridentboomer's Avatar
Dash removal
This is most likely a waste of time looking at the date your message was posted, but I am having major problems getting my dash out. I went to the web site you referenced to and downloaded the instructions and can't open it. I get a message "can't load graphics convertor. Any help appreciated.
Thanks....Bill
Old Sep 15, 2007 | 09:44 AM
  #182
mjh80401's Avatar
'99 f150 xlt. AC works fine, but no heat when I rotate the center **** to red - seems to be just ambient air. Temp guage comes up nicely; same as it always has. Replaced the AC potentiometer since it was only $15., and same problem (**** is ok too). Question is: if you pull the black kick-plate on the floor you can see the little white flat looking activation motor.. shouldn't you be able to feel some type of movement or detect activity if that's ok ?.. I guess it's either the activation motor ($73.) or the blend door ($44.). Dealer wants $1000. (labor only) to fix. NO WAY. I just really dont want to tear the dash apart, but I will if I have to.. can someone please send me some step-by-step info if it's available ?..
Old Sep 18, 2007 | 12:38 PM
  #183
mjh80401's Avatar
Actuator motor bad/blend door ok.
99 F150 4x4 5.4 102K. I too had no heat; just good AC. Thanks to the excellent instructions, I was successful in pulling the dash and opening up my plenum, only to discover that the blend door was ok. It was stuck in the closed position. Replaced it anyway ($40.), along with a new actuator motor ($73.). The new actuator did the trick. I did not replace my heater core, as the job wasn't too bad and I wanna get as many miles out of it as I can.
Now that I have it back together, the left turn signal blinks fast and the tail light wont blink - front is ok. Replacement bulb made no difference. Could something have gotten shorted out when the dash was pulled ?..
Old Sep 23, 2007 | 10:39 PM
  #184
tractionaction's Avatar
I had a similar problem on my '97 F150 4X4 It turned out to be the turn signal switch on the steering column. I simply cleaned all the contacts and re-lubed it. Once assembled it worked fine.
Old Sep 27, 2007 | 02:39 PM
  #185
weboman1's Avatar
Hey guys I hate to be a copy cat but can anyone send thosr instructions to me? My wif will be very happy to have AC again.....
Old Sep 27, 2007 | 02:46 PM
  #186
weboman1's Avatar
97 blend door actuator
Originally Posted by AlanT
I don't deserve a reward but the guy who wrote these instructions sure does! Check you inbox...you've got mail.
Alan
Alan I gusee you are the man.... and I am sure your email finger is getting tired but I you could send one more set of instructions that would make my wife happy.......
Weboman1
Old Oct 8, 2007 | 08:41 PM
  #187
gferreira's Avatar
No Heat on 2000 Expedition
Hi all, first of all, this is my first time on this forum and it is awesome. I too am having similar issues with my Expedition where I only get cool air both in the front and the rear vents and winter is right around the corner. I've downloaded the instructions but would like input on whether these instructions will also work on a 2000 Expedition. Earlier this week, I replaced the thermostat because the vehicle was overheating and was hoping that would resolve the heat issue as well, but I wasn't so lucky. Could someone also please point out the parts that I need to replace so that I can get them ordered?
Many thanks in advance,
George
Old Oct 15, 2007 | 02:26 PM
  #188
BOTLFED98's Avatar
is the blend door just for adjusting temperature or have anything to do from switching to/from vents/defrost/floor?
Old Oct 20, 2007 | 05:31 PM
  #189
tmwilkin's Avatar
Request for instructions on 97 f150 heater core replacement
Hey all, I'm getting ready to replace my heater core on a 2wd 97 F150. Can I get a copy or a pointer to a copy of those instructions ? Much appreciated.
Just looked again. I assuming these are the instructions
http://www.geocities.com/tractionaction/f150mso4B.pdf
So I think I have them already.
-Todd
Old Oct 26, 2007 | 08:46 PM
  #190
reecer's Avatar
1999 ford pickup blend door replacement
could I receive instructions of panel removal and blend door removal
reecer
Old Nov 4, 2007 | 02:37 PM
  #191
MrRobert's Avatar
Question HELP No HEAT!!!!
I have 99 F150 and no heat A/c Blows cold. I replace thermostat and still no heat, I can change temp control and I hear a difference but no HEAT still blows Cold!!! What could it be Heater core??? Can someone tell me what it might be or what to look for? Please email me at: mrrobertkuhner@yahoo.com
Old Nov 4, 2007 | 03:20 PM
  #192
mrandmrsjoe's Avatar
Robert...
I just downloaded the instructions myself I can email them to you if you like post your addy or one you don't care to post publicly.
Old Nov 4, 2007 | 03:21 PM
  #193
robert again..
And HA! we are in Louisville must be in the air
Old Nov 4, 2007 | 03:48 PM
  #194
opps
wrong person.. wow too much for my head today sorry
Old Nov 5, 2007 | 05:14 PM
  #195
lenora's Avatar
You've got mail too.
Alan
hi Alan do u still have the instruction on the blend door installation i could really u it i have a 97 f150 my email is lenrow_@hotmail.com thank you.
