Those with in dash screens and stock sub
'05 Lariat Audiophile
I put in a Clarion Max675VDII with a the audiophile wiring harness. After the install the factory sub was popping whenever I turned on the deck. I went to the local car audio shop. They told me I had to wire resistors in with the remote turn on wire because the factory amp uses a 6V turn on not 12V. I did and it solved the problem.
Originally Posted by guitarman502
yeh... like everyone says.. make sure you get the right wiring kit... crutchfield has it... but also... do a search on here... if i'm not mistaken you have to install a relay into the line somewhere to prevent a "pop" sound when the stock amplifier kicks on.
I don't know if a relay would work or not. Mach 1 (local kicker dealer) told me to cut the remote turn on wire from the deck, solder in a 500 ohmn resister, AFTER this resistor (toward amplifier side), solder in another 500 ohmn resistor to ground to blead off 6V. I'm looking for a program to make a quick wiring diagrahm so it's easier to under stand.
The other day I made a "harness" for the sub, all I did was get some splitters (2 males to 1 female or just a simple single rca if u got the mono plug on ure HU), plug the male(s) to the HU, cut off the female end then grab the exposed wires to tap into the sub wires + & -, then send ure remote turn on to the amp turn on w/ure resistors and ure good
here's the only diagram I could find a lil blurry
