There are these: http://www.stillen.com/product.asp?i...model=EXPEDITN
The only others I've see that make them. And, they're a full 2" :) |
Originally Posted by ELVATO
(Post 3817490)
Not sure. Just posting another alternative. :)
alright well I guess I'm going lower 2 inches all around :cool: just got to wait until the 14 cause the wife was saying she might need to borrow some money so we'll see what happens
For what it's worth Eibach makes a quality product. I've used their products on several VW's and other compact cars I've owned through the years. They make reliable products needless to say.
wait ELVATO i was just looking at the springs again and it says 2WD... mine is AWD do you think I could still use them ?
Not sure. Call them up? I have 2WD, so I'm good :)
i sent them an email, would .4 inches really make a difference ?
I sent an email and this is what they said
Edward, Greetings, this is Charlie from STILLEN. Thank you for your email and inquiry on Belltech Suspension. Unfortunately, for your 2005 AWD Expedition, a 2WD suspension will not work. Even though you don’t use the 4WD you still have 4WD suspension. Belltech only makes a Lowering kit for a 2WD Expedition. I have a 2”x2” drop available from Ground Force, which is another Top Quality Suspension Company, but it will only work on NON-AIR Ride Trucks. So if you do not have the rear Leveling system or rear Air Bags I would have a lowering kit available, and unfortunately if you do have the Leveling System or rear Air Bags I would not have a lowering kit available. If you could please verify the rear setup of your Expedition, I can get you more details on a lowering kit. |
old expy's had bags too, the 97-02s I would take a peak under your truck and see if you have bags before you order anything
i looked and all i see is springs so i'm assuming i don't have them..
i was also thinking about some grills which would you guys recommend Grill 1 http://i521.photobucket.com/albums/w...ar/113114b.jpg Grill 2 http://app.infopia.com/img/image/fp/.../img-2/img.jpg |
well i got an email from stillen... and the ground force springs for the AWD are $450
i have an 03 expy and will be getting my eibach springs on wednesday. putting them in with my new kyb gr2 shocks. will post pics as soon as i get them in. cant wait to see how they sit with my 24s
are you 4WD or 2WD
definitely not vertical bar grille
450 isnt bad, how much would shocks/struts run you? |
